Defining a Seating Weld Connection
With the Seating Weld Connection command, column-beam connection is defined
Location of the Seating Weld Connection Command
  • From the Connection menu, click on Seating Weld Connection icon.
  • If the connection is suitable, create the combination by clicking the left mouse button.
  • The seating weld connection settings dialog will open.
Location of the Seating Weld Connection Settings Dialog
Type Tab
Type
For connection, web, diagonal and gusset plate selections are made.
Schematic drawing
Cınnectons ​​are shown on the schematic drawing.
Preview
Cap and Stiffener Plates Tab
Cap plate
The cap plate is determined by entering the value. The values ​​to be entered are shown in the schematic drawing.
Beam stiffener plate
Beam stiffener plate is determined by entering the value. The values ​​to be entered are shown in the schematic drawing.
Schematic drawing
Preview
Chamfers Tab
Chamfer (c1, c2, c3, c4, c5)
Schematic drawing
Connection and chamfer values ​​are shown on the schematic drawing.
Preview
Welds Tab
Welds
Weld electrode
Schematic drawing
Preview
Web Plate Tab
Web plate
The web plate is determined by entering the value. The values ​​to be entered are shown in the schematic drawing.
Schematic drawing
Preview
Dioganal Plate Tab
Diagonal plate
The diagonal plate is determined by entering the value. The values ​​to be entered are shown in the schematic drawing.
Schematic drawing
Preview
Gusset Plates Tab
Column stiffener plate
The column stiffener plate is determined by entering the values. The values ​​to be entered are shown in the schematic drawing.
Stiffener plates' distances
It is determined by entering the values ​​of the stiffener plate. The values ​​to be entered are shown in the schematic drawing.
Far beam stiffener plate
The far beam stiffener plate is determined by entering values. The values ​​to be entered are shown in the schematic drawing.
Schematic drawing
Preview
Design Data Tab
