Column - Beam Joint Cross-Section
With the Column-Beam Joint Cross-Section command, the column-beam connection horizontal section of the project is created.
Location of the Column - Beam Joint Cross-Section Command
  • Click on the Column-Beam Joiny Cross-section.
  • The drawing properties dialog will open.
  • Click the OK button.
  • Column-beam joints of the working story will be automatically designed according to the scale and paper size specified in the drawing settings. One or more drawing windows can be created according to the size of the paper. The relevant window can be selected from the list under the Window menu.
  • In the drawings, all column-beam joints are arranged as blocks. You can split the blocks into sub-blocks with the explode. In the sub-blocks, again, the object can be divided into lines and writings with explode.
General Tab
Specifications - Colors
Steel line
Object ID
Object body
Specifications - Heights
Font
Paper Tab
Paper width
Paper height
Scale (1/X)
Standard paper sizes
Vertical/Horizontal use
Distance between layouts
Left margin
Right margin
Top margin
Bottom margin
Border color
Text color
Advanced Tab
Draw steel bar ids
Draw steel lengths
Arrange blocks by name
Draw slab loads
Anchorage length is 1/4
Enable drawing organizer
All stories
Min. distance between blocks
Distance between lines
