Slab Edge
In order to create a reinforced concrete slab, the slab borders must first be determined. The edges of the areas that are not covered with beams and shearwalls should be covered with the slab edge. Slab edge creation methods, slab edge settings are explained in detail under this title.
Slab Edge Settings
