With the 4 Bolts Unstiffened End Plate Connection command, column-beam connection is defined.
Location of the 4 Bolts Unstiffened End Plate Connection Command
From the Connection menu, click the 4 Bolts Unstiffened End Plate Connection icon.
The 4 bolts unstiffened end plate connection settings dialog will open.
Location of the 4 Bolts Unstiffened End Plate Connection Settings Dialog
Type and End Plates Tab
End plate
The end plate is determined by entering the values. The values to be entered are shown in the schematic drawing. |
Schematic drawing
Connectio and plate values are shown on the schematic drawing. |
Preview
Bolts Tab
Horizontal arrangement The horizontal arrangement distance value of bolts is entered. The values to be entered are shown in the schematic drawing. |
Group 1 The distance value of the bolts to the beam is entered. The values to be entered are shown in the schematic drawing. |
Group 2 The distance value of the bolts to the beam is entered. The values to be entered are shown in the schematic drawing. |
Group 3 The distance value of the bolts to the beam is entered. The values to be entered are shown in the schematic drawing. |
Bolt properties
Schematic drawing
Preview
Stiffeners Tab
Continuity plate
The purpose of the continuity plates is to support the column heads in the column-beam joints and to ensure the continuity of the beam head. Continuity plates are used for reinforcement in order to bend the column head and prevent column stem flow / wrinkle. If a continuity plate will be made, the option is marked. Continuity plate is determined by entering values. The values to be entered are shown in the schematic drawing. |
Schematic drawing
Preview
Extra Plates Tab
Web doubler plate
If the column body thickness is insufficient, web doubler plates are used to meet the shear effect of the panel area. If the web doubler plate will be made, the option is marked. Web doubler plate is determined by entering values. The values to be entered are shown in the schematic drawing. |
Schematic drawing
Preview
Chamfers Tab
Chamfers
Schematic drawing
Preview
Welds Tab
Welds
Weld electrode The strengths of the welding electrodes are defined in the design inputs. The strength of the main element in the weld joint is controlled under the condition that it has less strength than the weld strength. If necessary, click the list and define "Create New…". To create the welding electrode, give the information "Name" and "Weld metal tensile strength" in the dialog that opens after clicking "Create New". Welding geometry is determined automatically by the program. These properties can be changed to easily determine the joint properties. Geometry features are in accordance with industry standards and in the form specified in AISC. |
Schematic drawing
Preview
Design Data Tab
