Single Part Drawings
Single Part Drawing command is used to prepare single element drawings of the steel structures.
Location of the Steel Drawing Command
  • Click the Single Part Drawing icon.
  • Single part drawings will be created.
  • Before creating the drawings, you can access the Steel Drawing Settings dialog by clicking the settings button from the steel drawings dialog . From this dialog, layout settings, scales, fonts, etc. You can access parameters related to steel drawings.
Sample single part drawing
Assembly Drawings
