With the Save As command, the project being worked on can be saved in a different location with a different name. The existing project file is left with its current name and the project can be saved as a new copy under a different name or under a different folder/directory. After this process, the old project file is closed and work continues on the new file.
Location of the Save As Command
To save as:
Click the ideCAD logo on the ribbon menu at the top left of the screen and click the Save As icon from the menu that opens . The Save Project window will be displayed.
If you want to save the project under the folder where the current project file is located, enter a different name in the Project name line. Change to another folder if you want to save it with the same name.
Click the Save button.
A copy of the project will be created. It will be this project being worked on. The previous project file will be closed.
