Defining a 4 Bolts Stiffened End Plate Connection
With the 4 Bolts Stiffened End Plate Connection command, column-beam connection is defined.
Location of the 4 Bolts Stiffened End Plate Connection Command
  • From the Connection menu, click the 4 Bolts Stiffened End Plate Connection icon.
  •  Click the column and then the beam in the 3D perspective view.
  • The 4 bolts stiffened end plate connection settings dialog will open.
Location of the 4 Bolts Stiffened End Plate Connection Settings Dialog
Type and End Plates Tab
End plate
The end plate is determined by entering the values. The values ​​to be entered are shown in the schematic drawing.
Schematic drawing
Preview
Brackets Tab
Brackets
Brackets are determined by entering values. The values ​​to be entered are shown in the schematic drawing.
Schematic drawing
Preview
Bolts Tab
Horizontal arrangement
The horizontal arrangement distance value of bolts is entered. The values ​​to be entered are shown in the schematic drawing.
Group 1
The distance value of the bolts to the beam is entered. The values ​​to be entered are shown in the schematic drawing.
Group 2
Group 3
Bolt properties
Schematic drawing
Preview
Stiffners Tab
Continuity plate
The purpose of the continuity plates is to support the column heads in the column-beam joints and to ensure the continuity of the beam head. Continuity plates are used for reinforcement in order to bend the column head and prevent column stem flow / wrinkle. If a continuity plate will be made, the option is marked. Continuity plate is determined by entering values. The values ​​to be entered are shown in the schematic drawing.
Schematic drawing
Preview
Extra Plates Tab
Web doubler plate
If the column body thickness is insufficient, web doubler plates are used to meet the shear effect of the panel area. If the web doubler plate will be made, the option is marked. Web doubler plate is determined by entering values. The values ​​to be entered are shown in the schematic drawing.
Schematic drawing
Preview
Chamfers Tab
Chamfers
Schematic drawing
Preview
Welds Tab
Welds
Weld electrode
Schematic drawing
Preview
Design Data Tab
