How to ask a question in the customers portal?
After logging in to the customers portal, follow the steps below.
  • Click on one of the titles Concrete, Steel or Architectural Design with ideCAD.
If you are only a user of ideCAD Structural Concrete or ideCAD Architecture , the selection screen will not appear. Concrete Design with ideCAD or Architectural Design with ideCAD page opens.
  • Click on the title related to your question on the page that opens. If the titles do not match your question, click on the Other questions title.
  • You can direct your questions for customers portal on the page that opens.
  • Briefly write your question in the summary line. While writing your question, suggested articles on the subject will be listed under the title.
  • Explain your question in detail in the description section.
  • Add the documents you want to add to your question by clicking the Browse button in the Attachment section .
  • Add your projects with .cde extension.
  • Select the ideCAD version you are using from the Version section.
  • Click the Send button.
  • Your question will occur in the customers portal.
