With the Crane Connection command, column-crane beam connection is defined.
Location of the Crane Connection Command
After drawing your crane between the columns;
Click the Crane Connection row from the Connection menu.
Select the main element (column).
Choose the crane beams.
Location of the Crane Connection Dialog
Type and Geometry Tab
Type
One of the connection types is selected from the list. |
Bracket
It is determined by entering the bracket values. The values to be entered are shown in the schematic drawing. |
Schematic drawing
Preview
Seat Tab
Define plate geometry
If the option is selected, it is determined by entering the angle values. The values to be entered are shown in the schematic drawing. |
Use section
One of the ready profiles is selected from the list by checking the option. By clicking on the Load section button, you can reach the ready section library and reach the list of American and European finished rolling sections and select from the list. |
Length
Profile length value is entered. |
Schematic drawing
Preview
Connecting Plates Tab
Connecting plates
Connecting plates are determined by entering values. The values to be entered are shown in the schematic drawing. |
Schematic drawing
Connection and placement values are shown on the schematic drawing. |
Preview
Stiffeners Tab
Column stiffeners
Column stiffeners are determined by entering the values. The values to be entered are shown in the schematic drawing. |
Crane stiffeners
Crane stiffeners are determined by entering the values. The values to be entered are shown in the schematic drawing. |
Seat stiffeners
Seat stiffeners are determined by entering the values. The values to be entered are shown in the schematic drawing. |
Schematic drawing
Preview
Welds Tab
Welds
Schematic drawing
Preview
Crane Bolts Tab
Horizontal arrangement
The horizontal arrangement distance value of the bolts is entered. The values to be entered are shown in the schematic drawing. |
Group 1
Bolt properties
Schematic drawing
Preview
Stopper Tab
Use section
By checking the option, one of the ready profiles is selected from the list as a plug. By clicking on the Load section button, you can reach the ready section library and reach the list of American and European finished rolling sections and select from the list. |
Length
The length value is entered for the plug. |
Schematic drawing
Preview
Spacer Tab
Use section
By checking the option, one of the ready profiles is selected from the list as a stamp. By clicking on the Load section button, you can reach the ready section library and reach the list of American and European finished rolling sections and select from the list. |
Length
The length value is entered for the stamp. |
Schematic drawing
Preview
Connection Bolts Tab
Group 1
Bolt properties
Schematic drawing
Connectionand bolt placement values are shown on the schematic drawing. |
Preview
Design Data Tab
