DWG/DXF - 2D Import
DWG/DXF-2D (Import) command is used to open .dwg and .dxf files in 2D in ideCAD or load them into the project.
Location of the Import DWG/DXF - 2D Command
  • Click the İdeCAD logo in the upper left corner.
  • Click the Import/DWG/DXF-2B line from the menu that opens.
  • In the opened dialog, the file to be imported is selected and the Open button is clicked.
  • The DWG / DXF Import Options dialog will open.
  • The file will open when the necessary parameters are set in the dialog and the OK button is clicked.
Import Options Dialog
Select imported objects
If checked, all imported objects are automatically selected as a result of the import operation.
Block imported objects
If checked, all objects in the imported drawing will be made into a single block.
Import line weights
If checked, line weights are imported.
Convert to nearest colors
The colors of the objects in the imported drawing are converted to match the colors available on the color scale.
Convert to basic colors
The colors of the objects in the imported drawing are converted to primary colors.
Original dimensions/New dimensions
New dimension is defined to the drawing to be imported. When a value is entered in any row, other dimensions are automatically changed while preserving the original dimensions. The scale of the newly entered dimensions appears in the Scale row.
Scale
The dimensions of the drawing to be imported are enlarged/reduced to the entered value.
Offset
After import, the drawing is shifted by the given values.
Move to origin
If the option is selected, the lower left corner of the imported drawing is placed at the origin point.
