For DTS = 4a, Mdev> = 0.75Mo must be provided.
The Complete Message:
The condition ∑Mdev> = 0.75Mo must be met in reinforced concrete structural systems with unidirectional gear floor with DTS = 1, 1a, 2, 2a, 3a or 4a.
The condition ∑Mdev / M0> = 0.75 must be met in reinforced concrete structural systems with unidirectional gear floor with earthquake design class (DTS) 4a.
According to article 4.3.4.6 of TBDY , ductility level should be provided in mixed structural systems (4.3).
                                                              ∑ M DEV ≥ 0.75 M o                                                       (4.3)
Possible solutions:
  • Shearwall / shearwall group can be added to the structural system until the 4.3 condition is met.
  • Solution can be made by choosing high ductility level. ( A14 or A15 )
  • Different flooring type can be selected.
Icons:
