Ribbed-Waffle Slab Parameters
With the Ribbed-Waffle Slab Parameters command, the design parameters used in the design of concrete ribbed and waffle slabs are determined. Concrete cover, maximum and minimum reinforcement interval, etc. parameters are determined from the rib-waffle parameters window.
Location of the Rib-Waffle Parameters Dialog
Ribbon menu Analysis and Design tab Design Parameters title under the rib-waffle parameters by clicking the command of rib-waffle parameters can be found in the dialogue.
Rib - Waffle Parameters
It determines with parameters which criteria the program will comply with in concrete design and reabr placement stage.
Parameters with the ( % ) sign mean the percentage expression of the rebar ratio. It is the ratio of the cross-sectional area of ​​the reinforced concrete element to the rebar area expressed as a percentage.
Concrete cover
It is the distance from the center of gravity of the tensile or compression rebar inside the rib and waffle teeth to the outer face of the concrete.
Min. tensile percentage
The percentage of rebar that determines the minimum rebar to be placed in the tension zone in the rib-waffle thread. The percentage value of the gross area of ​​the rib-waffle specified in this parameter determines the minimum rebar area. In rib and waffle threads, this parameter is used at the bottom of the threads opening and at the top of the threads support. The minimum rebar area of ​​the concrete element means that the gross section will not be less than the percentage value entered with this parameter.
Maximum percentage
It is the rebar percentage that determines the maximum value of the tensile rebar (top rebar at the support, bottom rebar at the opening) to be placed on the rib-waffle thread. The percentage value of the rib-waffle gross area specified in this parameter determines the maximum rebar area. The maximum rebar area of ​​the concrete element means that the gross section will not exceed the percentage value entered with this parameter.
H for body reinforcement
If the height of the rib-waffle thread is more than the value specified in this parameter, 2 pieces of 10 body rebar are placed on the thread.
Min. stirrup interval
In the program, the spacing of the stirrup to be placed on the rib-waffle tooth is selected not less than the value specified in this parameter.
Max. stirrup interval
In the program, the spacing of the stirrup to be placed on the rib-waffle tooth is selected not to be more than the value specified in this parameter.
Min. B for double stirrup
The width of the rib-waffle thread is compared with this parameter. As long as the width of the thread does not exceed the minimum width specified in this parameter, the threads are equipped with a double arm stirrup. Otherwise, they are equipped with 2 double-armed stirrups.
Consider connecting beam rebars for stirrup lengths determination
When calculating the length of the gingiva, it is thought that it will be placed to surround the flat rebar at the bottom with the top mounting. When this option is checked, it is assumed that the flat rebars coming from the adjacent beam, if any, together with the top assembly are also included in the stirrup. As a result, the stirrup length is calculated with allowance for the rebars coming from the neighboring entrance at the top and the opening is drawn in that way.
