Steel column design results and failure conditions for steel columns are displayed in the Steel Columns dialog. The PMM ratios are shown in the Steel Columns dialog. In the Details tab, material and section properties, internal force values, axial compressive strength, bending moment strength in strong and weak axis, design variables and lateral stiffness coefficients (K coefficient, L factor, etc.) and PMM ratio are displayed.
Location of Steel Columns Dialog
After the analysis is done, you can access it by clicking the Column command under the Steel Design heading in the ribbon menu Analysis and Design tab.
Steel Columns
ID
It is the name of the steel column in the plan. |
Section
It is the section used in a steel column. |
Materiel
It is the material used in steel column. |
PMM Ratio
It is the ratio of requirement to section capacity (PMM Ratio = Need/Capacity). |
Combo.
It is the load combination that produces the most unfavorable PMM ratio. |
Maj-Shr-Ratio
It is the ratio of the shear force in the major direction of the section to the capacity in the major direction. |
Combo
It is the load combination that produces the most unfavorable stress ratio in the major direction. |
Min-Shr-Ratio
It is the ratio of the shear force in the minor direction of the section to the capacity in the minor direction. |
Combo
It is the load combination that produces the most negative stress ratio in the minor direction. |
Strength check
It is an information box whose sign changes depending on whether there is a negative aspect in the section or not. |
Slenderness
It is the slenderness value of the steel column. |
Limit Value
It is the maximum slenderness value allowed in the steel column. |
Slenderness check
This is an information box whose sign changes depending on whether the slenderness limit is exceeded or not. |
Details Design details are shown in detail. |
OK It saves the changes made and closes the dialog. |
Summary Information The summary information about the line where the cursor is located is given in the name of the dialog in Layer, pose format.
For example BASE STORY, SC001 |
Using the Shift key In this tab, you can select more than one row with the Shift key, enter a value by double-clicking any cell whose value is open to change, and make that value apply to all selected rows. |
Using the Ctrl key Ctrl key selects the lines in between one by one. |
Design Details
Schematic drawing
Section properties
It is the part where the name and geometric properties of the section take place.
Material properties
The properties of the steel material used in the section are listed.
Forces and moments
Internal forces occurring in the element, belonging to the selected load combination, are shown in this section.
Combo The load combination is selected. |
Demand/capacity ratio
The demand/capacity ratio in the section of the selected load combination is displayed.
Shear check
The shear capacity ratio of the steel column is shown.
Axial force and biaxial bending check
The axial capacity and moment capacity ratios of the steel column are shown.
Design factors
K factor: It is the effective length factor used in calculations.
