Creating a Cone-Creating Pyramids
With the Cone - Pyramid command, a cone or pyramid is created from 3D geometric objects.
Cone - Location of Pyramid Command
You can access the Cone - Pyramid command from the Tubes toolbar that opens after you enter the Tube command under the Objects title of the Ribbon menu Entry tab .
  • Click the Cone - Pyramid icon.
  • If you want, you can change the object properties by clicking the settings icon from the tubes toolbar.
  • At this stage, enter the object height in the value box on the auxiliary toolbar.
  • Click a point in the drawing area. The object will be formed.
Previewing the object and determining its location
Entering the object height in the value box on the tubes auxiliary toolbar
Creating the object by clicking the left mouse button
