How does ideCAD control One-Way slab reinforcement limits according to ACI 318-19?
A minimum area of flexural reinforcement, As,min is controlled and reported automatically.
The ratio of deformed shrinkage and temperature reinforcement area to gross concrete area is greater than or equal to 0.0018. It’s controlled automatically.
The spacing of deformed shrinkage and temperature reinforcement does not exceed the minimum of 5h and 18 in. It’s controlled automatically.
Ag = gross area of concrete section, in.2
As,min = minimum area of flexural reinforcement in.2
Minimum flexural reinforcement in nonprestressed slabs
A minimum area of flexural reinforcement, As,min is controlled automatically. Minimum flexural reinforcement is the same as required for shrinkage and temperature in 24.4.3.2. Compared with shrinkage and temperature reinforcement, flexural reinforcement should be placed as close to the face of the concrete in tension due to applied loads.
As,min =0.0018Ag
According to 24.4.3.2, the ratio of deformed shrinkage and temperature reinforcement area to gross concrete area is greater than or equal to 0.0018.
Minimum shrinkage and temperature reinforcement
Shrinkage and temperature reinforcements are determined according to 24.4.
The spacing of deformed shrinkage and temperature reinforcement does not exceed the lesser of 5h and 18 in.
