Rotate Building
With the rotate building command, the project is rotated by the entered angle with reference to the origin point. All 2D and 3D objects in the architectural and structural project are rotated.
Location of the Rotate Building Command
You can access it under the ribbon menu Tools tab , under the title Tools.
  • Click the Rotate Building icon in the ribbon menu .
  • The Rotate Building dialog will open.
  • Give the angle value and click the OK button.
Before rotate structure
Giving the angle of rotation
After rotate building
Incline Objects
