Defining a Apex Type Connection
With the Apex Type Connection command, column-inclined beam connection is defined.
Location of the Apex Type Connection Command
  • Click on the Apex Type Connection icon from the Connection menu.
Location of the Apex Type Connection Settings Dialog
Plates Tab
Type
Bolted or welded connection type is selected for the connection.
Plate 1
The plate 1 is determined by entering value. The values ​​to be entered are shown in the schematic drawing.
Plate 2
The plate 2 is determined by entering values. The values ​​to be entered are shown in the schematic drawing.
Schematic drawing
Preview
Brackets Tab
Bracket 1
The bracket 1 plate is determined by entering the values. The values ​​to be entered are shown in the schematic drawing.
Bracket 2
The bracekt 2 plate is determined by entering the values. The values ​​to be entered are shown in the schematic drawing.
Schematic drawing
Preview
Bottom Plates Tab
Plate 1
Plate 2
Schematic drawing
Preview
Chamfers Tab
Chamfer (c1)
Schematic drawing
Preview
Welds Tab
Welds
Weld electrode
Schematic drawing
Preview
Stiffener Plates Tab
Stiffener plates
Stiffener plates are determined by entering the values. The values ​​to be entered are shown in the schematic drawing.
Schematic drawing
Preview
Bolts Tab
Horizontal arrangement
Group 1
Group 2
Group 3
Bolt properties
Schematic drawing
Preview
Design Data Tab
