List of ideCAD Structural Commands
The list of commands available in the ideCAD Structural package program is given below in alphabetical order (Base version: 11.11)
Command
Location of command in ribbon menu or toolbar
Explanation
1
1.4G+1.6Q
Concrete/Structural Inspection/Modal
Shows deformation 1.4G+1.6Q visualization dialog page.
Steel/Structural Inspection/Modal
Structural Inspection/Deformation
2
3D Isometric View Drawings
Concrete/Create Drawings/Steel
Draws steel 3D isometric view.
Steel/Create Drawings/Steel
Drawings/Create Drawings/Steel
3
3D Printer (.OBJ)
Tools/Import-Export/Export
Exports to OBJ file format.
ideCAD logo/Export
4
3P Workplane
View/Workplane/Target Workplane
Creates a workplane through 3 points.
5
4 Bolts Stiffened End Plate Connection
Connection/Connection/4 Bolts Unstiffened End Plate Connection
Creates a 4 bolts stiffened end plate connection.
6
Creates a 4 bolts unstiffened end plate connection.
7
8 Bolts Stiffened End Plate Connection
Creates a 8 bolts stiffened end plate connection.
8
About ideCAD Structural
ideCAD logo/Help
It gives the program version and usage license information.
9
Activate Local CS
Drawings/Snap
Uses defined local coordinate system.
10
Add Custom Snap Points on Line
Right click menu in perspective view
Creates snap points on a line in a perspective image.
11
Add Lines to Edges
It is located in the hatch toolbar.
Adds lines to the hatch edges.
12
Add Point
Adds a new point to hatch.
13
Add Stair Area
Concrete/Concrete/Stair
Adds stair area to an existing stair.
14
Add to Selection Group
Right click menu
Adds new objects to previously created groups.
15
Add/Remove Dimension Parent
Modify/Entity Edit/Dimension
Adds/removes dimension parents.
16
Advanced Arrray
Drawings/Edit
Generates array of entities.
17
Advanced Snap
Drawings/Snap
Enables advanced snap mode.
18
Alias Editor
Settings/Settings
Edits commands used on the command line.
19
Align Bottom
It is located in the align toolbar.
Aligns the selected entities at the bottom.
20
Align by Drawing a Path
Aligns  the selected entities by drawing a path.
21
Align by Selecting an Edge of Entity
Align the selected entities by selecting an edge of entity.
22
Align Entities
Drawings/Modify
Aligns the selected entities.
23
Align Left
Aligns the selected entities to the left.
24
Align Object Center
Aligns the selected entities to the object center.
25
Align Nearest Point
Aligns the selected entities to the nearest point.
26
Align Right
Aligns the selected entities to the right.
27
Align Top
Aligns the selected entities to the top.
28
Analysis Design
Concrete/Analysis/Analysis Design
Does a complete analysis and structural design.
Steel/Analysis/Analysis Design
Analysis and Design/Analysis/Analysis Design
Structural Inspection/Analysis/Analysis Design
29
Analysis Model
Shows analysis model visualization dialog page.
View/View
Structural Inspection/View
30
Analysis Settings
Concrete/Project Settings
Opens analysis settings.
Steel/Project Settings
Analysis and Design/Building
31
Analysis Settings Report
Concrete/Reports/Concrete/Structure Summary
Reports the settings based on the analysis.
Steel/Reports/Concrete/Structure Summary
32
Angle
Tools/Reference
Measures the angle.
Drawings/Reference
33
Angle (Coordinate Box)
Coordinate Box
A enters the coordinate box. Angle is entered.
34
Angle Dimension
Drawings/Dimensions
Draws angle dimension.
35
Angle Dimension Settings
Drawings/Dimensions/Level Dimension
Opens angle dimension settings.
36
Angled Library Placement
It is located in the library toolbar.
Sets vertical angle of library automatically using underlying geometry.
37
Apex Type Connection
Connection/Experimentals/Haunch
Creates a apex type connection.
38
Application Plan Drawings
Draws steel application plan.
39
Arc (Center-Radius-Angles)
It is located in the primitives toolbar.
Draws arc.
40
Arc Axis
Concrete/Axis
Draws arc axis.
Steel/Axis
41
Arc Axis Through 3Points
Concrete/Axis
Draws arc axis through 3 points.
Steel/Axis
42
Arc Beam
Concrete/Concrete
Draws arc beam.
43
Arc Dome
Objects/Roof/Dome
Draws arc dome.
44
Arc Dome 3P
Objects/Roof/Dome
Draws arc dome through 3 points.
45
Arc Scaffolding Macro
Concrete/Scaffolding/Scaffolding Macro
Creates arc scaffolding.
46
Arc Slab Band
Concrete/Concrete/Slab
Draws arc slab band.
47
Arc Slab Edge
Concrete/Concrete/Slab Edge
Draws arc slab edge.
48
Arc Through 3 Points
Draws arc through 3 points.
49
Arc Wall
It is located in the wall toolbar.
Draws arc wall.
50
Area
Tools/Reference
Calculates area.
Drawings/Reference
51
Array
Drawings/Edit
Generates an array of entities.
52
AS Calculator
Tools/Reference
Area of steel calculator.
53
AS1 Under
Structural Inspection/Shell Elements/AS1 Visible
Shows shell AS1 under visualization dialog page.
54
AS1 Upper
Shows shell AS1 upper visualization dialog page.
55
AS1 Visible
Shows shell AS1 visible visualization dialog page.
56
AS2 Under
Structural Inspection/Shell Elements/AS2 Visible
Shows shell AS2 under visualization dialog page.
57
AS2 Upper
Shows shell AS2 upper visualization dialog page.
58
AS2 Visible
Shows shell AS2 visible visualization dialog page.
59
Assembly Drawings
Draws steel assembly.
60
Assembly Drawings with Single Parts
Draws steel assembly with single parts.
61
Auto Label Entities
Modify/Entity Edit
Auto label entities.
Tools/Tools
62
Automatic Analysis System Generation
Turns automatic analysis system generation on/off.
63
Automatic Hatch
Creates hatch with closed polygons.
64
Axial Force
Concrete/Structural Inspection/Moment 3-3
Shows frame axial force visualization dialog page.
Steel//Structural Inspection/Moment 3-3
Structural Inspection/Frame Results
65
Axial Force (Shearwalls)
Structural Inspection/Shearwall
Shows shearwall axial force visualization dialog page.
66
Axis
Concrete/Axis
Draws axis.
Steel/Axis
67
Axis Border
Modify/Entity Edit/Move Axis Label
Sets the axis border.
68
Axis and Frontal View Drawings
Draws steel axis and frontal view.
69
Axis Offset
It is located in the axis toolbar.
Draws an axis with an offset to the previous axis drawn.
70
Axis Settings
Concrete/Axis/Axis
Opens axis settings.
Steel/Axis/Axis
71
Axonometric
View/Perspective
Changes view to axonometric.
72
Back
View/Perspective
Changes view to back.
73
Beam (Steel)
Steel/Steel
Draws steel beam.
74
Beam (Concrete)
Concrete/Concrete
Draws concrete beams.
75
Beam (Reinforcement Design)
Concrete/Design/Concrete
Display the calculation results of the beams and the selected reinforcements.
Steel/Design/Concrete
Analysis and Design/Concrete Design
76
Beam (Steel Design)
Concrete/Design/Steel
Display steel beam design results.
Steel/Design/Steel
Analysis and Design/Steel Design
77
Beam (Report)
Display beam general report.
Reports/Concrete
78
Beam Drawings
Concrete/Create Drawings/Concrete
Prepares beam drawings.
Steel/Create Drawings/Concrete
Drawings/Create Drawings/Concrete
79
Beam Live Loads (Concrete)
Structural Inspection/Input
Shows concrete design in beam live loads visualization dialog page.
80
Beam Parameters
Analysis and Design/Design Parameters/Concrete
Opens beam parameters.
81
Beam Settings
Concrete/Concrete/Beam
Opens beam settings.
82
Beam To Shearwall
Modify/Transform
Converts beams to shearwalls.
83
Beam Live Loads (Steel)
Structural Inspection/Input/Steel
Shows steel design in beam live loads visualization dialog page.
84
Bearing Capacity Failure (Foundations)
Structural Inspection/Output/Concrete All Failures
Shows concrete design out bearing capacity failure visualization dialog page.
85
Bezier
Drawings/Primitives/NURBS
Draws bezier curve.
86
Bitmap Hatch
Drawings/Hatch
Draws bitmap hatch.
87
Bolted Flange Plate Connection
Creates a bolted flange plate connection.
88
Border Vault
Objects/Roof/Vault
Draws border vault.
89
Bottom
View/Persoective
Changes view to bottom.
90
Box/Tube Cap Plate
Connection/Experimentals/Multi Stiffener Plate
Creates box/tube cap plate.
91
Box/Tube End Plate Connection
Connection/Experimentals/Box-Tube Splice Connection
Creates a box/tube end plate connection.
92
Box/Tube Seating Connection
Connection/Experimentals/Welded Connection
Creates a box/tube seating connection.
93
Box/Tube Splice Connection
Creates a box/tube splice connection.
94
Brace (Steel)
Steel/Steel
Draws steel brace.
95
Brace (Steel Design)
Display steel brace design results.
Steel/Design/Steel
96
Brace Center Connection
Connection/Connection/Brace Corner Connection
Creates a brace center connection.
97
Creates a brace corner connection.
98
Break
Drawings/Modify
Breaks off a certain part of the objects.
99
Calculate Contour
Concrete/Axis/Axis
Calculates contour polygon.
Steel/Axis/Axis
100
Cancel Secondary Stair Deformation
Modify/Entity Edit/Stair
Cancels secondary stair deformation.
101
Cancel Stair Deformation
Cancels stair deformations.
102
Castellated Beam (Report)
Concrete/Reports/Steel
Creates castellated beam design report.
Steel/Reports/Steel
Reports/Steel
103
Centered Column
It is located in the column toolbar.
Sets center aligned.
104
Centered Single Footing
It is located in the single footing toolbar.
Sets centered single footing.
105
Chamfer
Drawings/Modify
Connects two lines with a third line.
106
Change Axis Draw Type
Concrete/Axis
Changes axis drawing type.
Steel/Axis
107
Change Baluster Count
Changes baluster count.
108
Change Column Dimension
Modify/Entity Edit/Column
Changes column dimensions.
109
Change Concrete Calculation Line Geometry
Concrete/Concrete
Changes validity extent and/or moves concrete calculation line.
Concrete/Foundation
ModifyEntity Edit/Slab
110
Change Distance Point
It is located in the ODT door/window toolbar.
Change dio distance point.
111
Change Entity Layers
Modify/Layers
Changes layers of selected entities.
112
Change Jacket Edge
Changes column jacket edge thickness.
113
Change Layers
Right click menu in plan view.
114
Change Rafter Dimensions
It is located in the roof details toolbar.
Changes rafter dimensions.
115
Change Roof Edge Properties
It is located in the roof toolbar.
Changes roof edge properties.
116
Change Shearwall Length
Concrete/Concrete/Shearwall
Changes shearwall length.
117
Check for Updates
ideCAD logo/Help
Check for updates.
118
Check Geometry
Tools/Tools
Checks validity of project geometry.
119
Circle
Drawings/Primitives
Draws circle.
120
Circle Beam
Draws circle beam.
121
Circle Slab Edge
Draws circle slab edge.
122
Circle Wall
Draws circle wall.
123
Circular Column
Concrete/Concrete
Draws circular columns.
124
Circular Column to Rectangular
Modify/Transform/Beam to Shearwall
Converts circular columns to rectangular columns.
125
Clash Check
Performs a 3D clash check.
Steel/Design/Steel
126
Clone
Drawings/Edit
Clones (immediately copies) objects.
127
Close
ideCAD logo
Closes current project.
128
Close Entity Layer
Right Click Menu
Closes the layer of the object.
129
Closed Bezier
Draws closed bezier curve.
130
Closed NURBS
Draws closed NURBS curve.
131
Closed Polygon To Polygon Column
Transforms primitive entities to polygon column.
132
Closed Polygon To Polygon Section
Transforms primitive entities to polygon section.
133
Collapse All
Right click menu in structure tree.
Collapses all structure tree items.
134
Collar Beam
Objects/Roof
Draws a collar beam.
135
Column (Concrete)
Concrete/Concrete
Draws rectangular column.
136
Column (Steel)
Steel/Steel
Draws steel column.
137
Column (Reinforcements Design)
Column reinforcements.
138
Column (Steel Design)
Display steel column design results.
Steel/Design/Steel
139
Column (Report)
Display column general report.
Reports/Concrete
140
Column Anchorage Drawings
Draws steel column anchorage.
141
Column Application Plan
Prepares column application plan.
142
Column Parameters
Opens column parameters.
143
Column Settings
Concrete/Concrete/Column
Opens column settings.
144
Column Support
Concrete/Concrete
Draws column support.
145
Column to Shearwall
Converts columns to shearwalls.
146
Column Vertical Drawings
Prepares column vertical drawings.
147
Column-Beam Joint Cross-section
Create column-beam joint cross-section.
148
Column-Beam Joint Safety (Report)
Prepares column-beam joint safety report.
Reports/EQ Code
149
Column-Beam Stiffened End Plate
Creates a column-beam stiffened end plate connection.
150
Column-Column Connection (Built Up Column)
Connection/Experimentals/Column-Column End Plate Splice
Creates a built up column connection.
151
Creates a column-column end plate splice connection.
152
Column-Foundation Connection (Stiffened Baseplate)
Creates a column-foundation connection (Stiffened baseplate).
153
Column/Shearwall Punching
Column/Shearwall punching dialog.
154
Combination
Analysis and Design/Define
Adds a new combination.
155
Components Report
Tools/Quantity Report
Creates components report.
156
Composite Beam (Steel Design)
Display composite beam design results.
Steel/Design/Steel
157
Composite Beam (Report)
Creates composite beam design report.
Steel/Reports/Steel
Reports/Steel
158
Composite Castellated Beam (Steel Design)
Display composite castellated beam design results.
Steel/Design/Steel
159
Composite Castellated Beam (Report)
Creates composite castellated beam design report.
Steel/Reports/Steel
Reports/Steel
160
Composite Slab
Steel/Steel
Draws composite slab.
161
Composite Solid Slab
Steel/Steel/Composite Slab
Draws composite solid slab.
162
Compound Shearwall (Report)
Prepares compound shearwall report.
Reports/Concrete
163
Concentric Brace (Report)
Creates concentric braces report.
Steel/Reports/Steel
Reports/Steel
164
Concentrically Braced Frame
Select concentrically braced frame members.
Steel/Design/Steel
165
Shows concrete design out all failures visualization dialog page.
166
Concrete Axial failure
Shows concrete design out axial failure visualization dialog page.
167
Concrete Capacity Ratio
Shows concrete capacity ratio visualization dialog page.
168
Concrete Column-Beam Joint Area
Shows concrete design out columnt-beam joint area failure visualization dialog page.
169
Concrete Critical shearwalls
Structural Inspection/Design/Concrete
Shows concrete design out critical shearwalls visualization dialog page.
170
Concrete Deflection Failure
Shows concrete design out deflection failure visualization dialog page.
171
Concrete Design Settings Report
Prepares concrete Design Settings Report.
172
Concrete Insufficient Rebar Area
Shows concrete design out insufficient rebar area visualization dialog page.
173
Concrete Insufficient rebar development length
Shows concrete design out insufficient rebar development length visualization dialog page.
174
Concrete Longitudinal rebar percentage (%-Beam endpoints)
Shows concrete design out longitudinal rebar percentage (%-beam endpoints) visualization dialog page.
175
Concrete Longitudinal rebar percentage (%-Beam spans)
Shows concrete design out longitudinal rebar percentage (%-beam spans) visualization dialog page.
176
Concrete Longitudinal rebar percentage (%-Columns)
Shows concrete design out longitudinal rebar percentage (%-columns) visualization dialog page.
177
Concrete Longitudinal rebar percentage (%-Shearwalls)
Shows concrete design out longitudinal rebar percentage (%-shearwalls) visualization dialog page.
178
Concrete Performance analysis - brittle elements
Structural Inspection/Design/Performance
Shows concrete performance analysis (brittle elements) visualization dialog page.
179
Concrete Punching Failure (Foundation Slabs)
Shows concrete design out punching failure (foundation slabs) visualization dialog page.
180
Concrete Punching Failure (Story Slabs)
Shows concrete design out punching failure (story slabs) visualization dialog page.
181
Concrete Rebar Perc. Above Limit
Shows concrete design out elements which have rebar percentage above the allowed limit visualization dialog page.
182
Concrete Section Failure
Shows concrete design out section failures visualization dialog page.
183
Concrete Shear Failure
Shows concrete design out shear failures visualization dialog page.
184
Concrete Slab
Draws concrete slab over steel beams.
185
Concrete Torsional failure
Shows concrete design out torsional failure visualization dialog page.
186
Concrete crack failure
Shows concrete design out crack failure visualization dialog page.
187
Concrete Formwork Report
Reports/Formwork
Creates concrete formwork report.
188
Configure Work Planes
Right click menu.
The workplane dialog opens and editing is done.
189
Connection (Steel Design)
Concrete/Design
Display connection design results.
Steel/Design
190
Connection (Report)
Concrete/Reports
Creates connection design summary report.
Steel/Reports
Reports/Steel
191
Connection Beam
Displays the calculation results of the coupling beams and the selected reinforcements.
192
Connection Beam Drawings
Prepares coupling beam drawings.
193
Connection Beam Settings
Concrete/Foundation/Coupling Beam
Opens coupling beam settings.
194
Connection electrode types
Shows steel design in electrode types visualization dialog page.
195
Connection plate materials
Shows steel design in connection plate materials visualization dialog page.
196
Contents
ideCAD logo/Help
Opens the program's help document.
197
Continuous Arc Beam
Concrete/Concrete
Draws continuous arc beams.
198
Continuous Arc Wall
Concrete/Wall
Draws continuous arc walls.
199
Continuous Beam Connection
Creates a continuous beam connection.
200
Continuous Slab Edge
Draws continuous slab edges.
201
Contour Lines
Concrete/Axis/Axis
Sets contours of the drawing.
Steel/Axis/Axis
202
Copy
Drawings/Edit
Copies entities.
203
Copy Contour
Tools/Edit
Copies contours of a drawing.
204
Copy To File
Tools/File Sharing
Copies entities to a .blk file.
205
Corner Aligned Column
Sets corner aligned column.
206
Corner Aligned Single Footing
Sets corner aligned single footing.
207
Coupling Beam (Concrete)
Concrete/Foundation
Draws coupling beam.
208
Coupling Beam (Report)
Prepares coupling beam report.
209
Coupling Beam Parameters
Opens coupling beam parameters.
210
Crane
Steel/Macro
Draws Crane.
211
Crane Beam (Steel Design)
Display crane beam design results.
Steel/Design/Steel
212
Crane Connection
Creates a crane connection.
213
Crane Design (Report)
Creates crane design report.
Steel/Reports/Steel
Reports/Steel
214
Create Clip Plane
View/Workplane
Creates a clip plane.
215
Create Custom Section
Right click menu in structure tree steel section part.
Creates a user defined section.
216
Create New Layout
Drawings/Layout Design
Creates a new layout window.
217
Create New Selection Group
Right Click Menu
Makes the selected objects a new group.
218
Create New Stair
Creates a new stair.
219
Create User Defined Hatch
Creates user defined hatch from block objects.
220
Crosstie
Objects/Reinforcement
Draws a crosstie between two circles.
Drawings/Reinforcement
221
CSICOL
Exports columns and shearwall groups to CSICOL software.
ideCAD logo/Export
222
Curve Beam
Concrete/Concrete
Draws curve beam.
223
Curve Slab Edge
Draws curve slab edge.
224
Curve To Beam
Converts circle, arc, ellipse objects to beams.
225
Curve To Shearwall
Converts circle, arc, ellipse objects to shearwalls.
226
Curve Wall
Concrete/Wall
Draws curve wall.
227
Customize
Right-click on any point of the vertical toolbar
Customize the vertical toolbar and the customizable toolbar on the top edge.
228
Default Aligned Column
Sets default aligned.
229
Default Single Footing
Sets default single footing.
230
Define CS Origin
Drawings/Snap
Defines temporary coordinate system origin.
231
Define Seismic Isolator
Defines seismic isolator.
It is located in the shearwall toolbar.
232
Deform Stair
Deforms stair.
233
Delete
Drawings/Edit
Delete entities.
234
Delete Old Entities on Mirror
It is located in the mirror toolbar.
Delete old entities on mirror.
235
Delete Primitives
It is located in the pool toolbar.
Delete primitives after pool creation.
236
Delete Roof Element
Deletes roof element(s).
237
Delete Slab Hole
It is located in the slab for steels toolbar.
Deletes slab hole.
238
Delta
Changes delta value.
It is located in the beam toolbar.
It is located in the strip footing toolbar.
It is located in the retaining wall toolbar.
239
Deselect All
Drawings/Edit
Deselects all entities.
240
Design Components
Design components.
241
Disable Object Filter
Right click menu
Closes the layer of the opened object.
242
Display Vertical Frame
View/Workplane
Display a vertical frame.
243
Distance
Tools/Reference
Calculates distance.
Drawings/Reference
244
Distribute by Drawing a Path
It is located in the distribute toolbar.
Distribute by drawing a path.
245
Distribute by Selecting an Edge of Entity
Distribute by selecting an edge of entity.
246
Distribute Entities
Drawings/Modify
Distrubutes the selected entities.
247
Distribute Horizontally
Distrubutes selected entities to the horizontally.
248
Distribute Object Center
Distribute selected entities to the object center.
249
Distribute Nearest Point
Distribute selected entities to the nearest point.
250
Distribute Vertically
Distrubute selected entities to the vertically.
251
Divide
Drawings/Modify
Divides the objects to the desired number.
252
Divide-Combine All Intersections
Steel/Steel/Purlin
Divides and combines on all intersections.
253
Divide-Combine Single Intersection
Steel/Steel/Purlin
Divides and combines on selected intersections.
254
Dome
Objects/Roof
Draws dome.
255
Dome (Concrete)
Display the calculation results of the domes and the selected reinforcements.
256
Dome & Vault Analysis
Does dome/vault analysis.
257
Dome Drawings
Generates dome drawings.
258
Dome Settings
Objects/Roof/Dome
Opens dome settings.
259
Dome Vault Parameters
Opens dome and vault parameters.
260
Dome/Vault Results (Report)
Prepares dome/vault results report.
261
Double Angle Connection
Creates a double angle connection.
262
Double Plate Seating Connection
Connection/Experimantals
Creates a double plate seating connection.
263
Double Vault
Steel/Macro/Truss
Draws Double Vault Truss.
264
Drafting Mode
Tools/Tools
Enters drafting mode.
265
Draw Concrete Calculation Line (Raft Foundation)
Concrete/Foundation
Draws calculation lines on raft foundation of concrete design.
266
Draw Concrete Calculation Line (Slab)
Concrete/Concrete
Draws calculation lines on slabs of concrete design.
267
Draw Line Weights
View/View
Display the line thicknesses defined for primitive objects on the plan view.
268
Draw New Stair Concrete Calculation Line
Draws new stair concrete calculation line.
269
Draw Similar Entity
Right click menu
Draws similar entity of the selected one.
270
Draw Single Steel Brace
Steel/Steel/Brace
Draws single steel brace.
271
Draw Slab Hole
Draws slab hole.
272
Draw Steel Brace Multiple Elements
Steel/Steel/Brace
Draws steel brace with multiple steel elements.
273
Draw in Fast Mode
Connection/Mode
Draws connection in fast mode.
274
Drawing List
View/Window
Display drawing list.
Drawings/Window
275
Drawings
View/Window
Arrange drawings in the project.
276
DWG/DXF As Structure
Tools/Import-Export/Import
Imports DWG DXF file formats as structure elements.
ideCAD logo/Import
277
DWG/DXF-2D
Imports DWG DXF file formats.
ideCAD logo/Import
278
DWG/DXF/DWF
Exports to DWG DXF DWF file formats.
ideCAD logo/Export
279
DWG/DXF/DWF single
ideCAD logo/Export
280
Dynamic Analysis (Report)
Concrete/Reports
Prepares dynamic analysis report.
Steel/Reports
Reports/Dynamic Analysis
281
EQ Code General Report
Concrete/Reports
Prepares EQ code general report.
Steel/Reports
Reports/EQ Code
282
Eaves Haunch
Creates a eaves haunch connection.
283
Eccentric Brace (Report)
Creates eccentric braces report.
Steel/Reports/Steel
Reports/Steel
284
Edge Aligned Single Footing
Sets edge aligned single footing.
285
Edit Concrete Calculation Line
Concrete/Concrete
Edit concrete calculation line.
Concrete/Foundation
Modify/Entity Edit/ Slab
286
Edit Entity Loads
Modify/Add Load
Edits loads.
287
Edit Label Text
Edit label text.
288
Edit Slab Edge
Edit slab edge.
289
Edit Stair
Edit stair.
290
Edit Stair Concrete Calculation Line
Edit stair concrete calculation line.
291
Edit Text
Modify/Entity Edit
Edit text.
Drawings/Text
292
Element Lengths (Concrete)
Structural Inspection/Input/Concrete
Shows concrete design in element lengths visualization dialog page.
293
Element Lengths (Steel)
Shows steel design in element lengths visualization dialog page.
294
Element Materials (Concrete)
Shows concrete design in element materials visualization dialog page.
295
Element Sections (Concrete)
Shows concrete design in element sections visualization dialog page.
296
Element Sections (Steel)
Shows steel design in element sections visualization dialog page.
297
Element materials (Steel)
Structural Inspection/Steel
Shows steel design in Element Materials visualization dialog page.
298
Elevation Line (Drawings)
It is located in the section toolbar.
Draws elevation line for creating elevation.
299
Elevation Line
Objects/Terrain
Draws elevation line.
300
Elevation Point
Objects/Terrain
Draws elevation point.
301
Ellipse Corner
Drawings/Primitives
Draws ellipse using corner.
302
Ellipse Center-Corner
Drawings/Primitives/Ellipse Corners
Draws ellipse using center and corner.
303
Ellipse Mid-Axis
Draws ellipse using midpoint and axis.
304
Elliptical Arc Center-Corner
Draws elliptical arc using center and corner.
305
Elliptical Arc Corners
Draws elliptical arc using corners.
306
Elliptical Arc Mid-Axis-Angles
Draws elliptical arc using midpoint and axis.
307
End Plate Shear Connection
Connection/Connection/Single Plate Connection
Creates an end plate shear connection.
308
End Plate Truss Connection
Connection/Experimentals/Seating Support Connection
Creates an end plate truss connection.
309
End Plate Truss Connection For Box/Tube
Creates an end plate truss connection for box/tube.
310
Enter
Keyboard
Runs the command. It has functions in various command stages.
311
Entity From Primitives
Tools/Generate
Entity from primitives.
312
Entity Properties
Modify/Entity Properties
Changes entity properties.
313
Esc
Keyboard
Exits the found command.
314
Euler Buckling Case
Analysis and Design/Define/Load Case
Adds a new euler buckling case.
315
Excel.xlsx
ideCAD logo/Export
Export information such as story parameters, story displacements, internal forces etc. to Excel
316
Exchange Coordinates
Exchange coordinates.
317
Exit
ideCAD logo
Quits the application.
318
Expand All
Expands all structure tree items.
319
Explode
Drawings/Modify
Separates the blocks into sub-blocks.
320
Explode Into Single Elements
It is located in the steel beam toolbar.
Explodes and groups multi-element entities into single elements.
It is located in the steel purlin toolbar.
321
Export Component Database To AMP
Tools/Quantity Report/Export
Exports components as a database file To AMP.
322
Export Component Database To OSKA
Exports components as a database file To OSKA.
323
Export Static Quantities Database To AMP
Exports static quantities as a database file To AMP.
324
Export Static Quantities Database To OSKA
Exports static quantities as a database file To OSKA.
325
Extend
Drawings/Modify
Line extends primitive objects such as arcs to another line or arc.
326
Fascia Board
Objects/Roof
Draws fascia boards.
327
Fast Move
Drawings/Modify
Activates fast move.
328
Fiber Reinforced Polymer Library
Settings/Settings
Edit/create fiber reinforced polymer materials.
329
Fillet
Drawings/Modify
It connects two lines with an arc.
330
Find & Replace
Tools/Tools
Finds entities based on their labels and change the labels.
331
Find Hatch Holes
Finds hatch holes.
332
Find in perspective
Right click menu
Displays an element in plan view in perspective view.
333
Find in plan
Right click menu
Displays an element in perspective view in plan view.
334
Connection/Experimental/Stiffened Shear Plate Connection
Creates a flange plate connection.
335
Flat
Steel/Macro/Truss
Draws Flat Truss.
336
Fly Mode
Opens fly mode.
337
Formatted Text
Drawings/Text
Draws formatted text.
338
Formwork Drawings
Prepares concrete formwork plan.
339
Formwork Plan
Prepares formwork plan.
340
Foundation Plan
Prapares foundation plan.
341
Free Dimension
Drawings/Dimensions
Draws free dimension.
342
Free Dimension Settings
Drawings/Dimensions/Free Dimension
Opens free dimension settings.
343
Freehand
Drawings/Primitives
Draws freehand curve.
344
Free Mode Slab
Creates a free mode slab by selecting boundary entities manually.
345
Friction Shear Failure
Shows concrete design out friction shear failure visualization dialog page.
346
Front
View/Perspective
Changes view to front.
347
GM records for Mode Superposition
Determine ground motion records for mode superposition method.
348
General Concrete Reinforcement Parameters
Opens general concrete reinforcement parameters.
349
General Construction Drawing
Draws steel general construction.
350
General Construction Drawing w/ Single Parts And Assembly
Draws steel general construction w/ single parts and assembly.
351
Generate 2D Drawing
Tools/Generate
Generates a 2D simple drawing using current drawing.
352
Generate Analysis System
Generates Analysis System.
353
Generate Vector Drawing
Tools/Generate
Generates vector drawing.
354
Geotechnic Report
Reports/Foundation
Predesign Results for Geotechnic Report.
355
Get Elevation From Terrain
It is located in the terrain toolbar.
Get elevation from terrain.
356
Get Entity Settings
Modify/Modify
Picks settings from entity.
357
Get Selection
Tools/Selection Groups
Gets currently selected entities.
358
Girt Connection
Connection/Experimentals/Purlin Connection
Creates a girt connection.
359
Ground Motion Scaling in Time Domain
Ground Motion Scaling in Time Domain.
360
Group List
Groups selected entities and selects entities based on these groups.
361
Hall
Steel/Macro
Creates hall.
362
Hand Rail
Steel/Macro
Creates steel hand rail.
363
Hatch Hole
Drawings/Hatch
Draws hatch hole.
364
Hatch Settings
Drawings/Hatch/User Defined Hatch
Opens hatch settings.
365
Haunch
Creates a haunch connection.
366
Hidden Line
View/View/Solid with Edges
Changes view detail to hidden line.
367
Hidden Line - Black & White
View/View
Changes view detail to hidden line black && white.
368
Hide/Filter Object
Right click menu
Removes all selected entities in the 3D view.
369
Hip/Valley Rafter
Objects/Roof
Draws hip/valley rafters.
370
Hole
Objects/Terrain
Draws hole.
371
Home
Keyboard
Centers the image in fly mode.
372
Horizontal Workplane
Creates a horizontal workplane.
373
IFC Import
Imports IFC file. Merges file content with current project.
ideCAD logo/Import
374
IFC Export
Exports project to IFC.
ideCAD logo/Export
375
Import Text
Drawings/Text
Imports text from a text file.
376
In background
Right click menu/Drawing order
Sends the selected object to the background.
377
In foreground
Sends the selected object to the foreground.
378
In background of object
Sends the selected object behind a certain object.
379
In foreground of object
Sends the selected object in front of a certain object.
380
Incline Objects
Modify/Entity Edit
Makes the selected objects beveled according to the given slope values.
381
Inner Dimension
Drawings/Dimensions
Draws inner dimension.
382
Inner Dimension Settings
Opens inner dimension settings.
383
Insert Layout Block
Drawings/Layout Design/Create New Layout
Inserts a layout block.
384
Insertion Point
Changes insertion point.
It is located in the stair toolbar.
385
Intersection Dimension
Drawings/Dimensions
Draws intersection dimension.
386
Invert Selection
Drawings/Edit
Inverts current selection.
387
ideCAD Home
ideCAD logo
Opens the start page.
388
Join
Drawings/Modify
Joins linear objects.
389
Joining Plates Connection
Creates a beam-beam connection (Joining plates).
390
L (Coordinate Box)
Coordinate Box
L enters the coordinate box. Object length is entered.
391
Label
Drawings/Dimensions
Draws label.
392
Label Entities
Modify/Entity Edit
Label entities.
393
Last Selection
Drawings/Edit
Selects last selected entities.
394
Lath
Objects/Roof
Draws laths.
395
Layer
Settings/Settings
Opens layer settings.
396
Layer Settings
Right click menu on the plan view.
397
Layout Settings
Changes settings of current layout.
398
Left
View/Perspective
Changes view to left.
399
Left Middle Aligned Column
Sets edge left middle aligned.
400
Level Dimension
Drawings/Dimensions
Draws level dimension.
401
Level Dimension Settings
Opens level dimension settings.
402
Library
Objects/Entities
Draws library.
Drawings/Primitives
403
Library Settings
Drawings/Primitives/Library
Opens library settings.
404
Line Slab Band
Draws line slab band.
405
Linear Performance Analysis
Performs a linear performance analysis of the building.
406
Linear Raft Foundation Load
Concrete/Foundation/Raft
Draws linear raft foundation load.
407
Linear Slab Load
Concrete/Concrete
Draws linear slab load.
408
Live Loads
Concrete/Structural Inspection/Wall
Shows live loads visualization dialog page.
Steel/Structural Inspection/Wall
Structural Inspection/Loads/Wall
409
Load Library
Settings/Settings
Edit/create loads.
410
Load Section From Library
Right click menu in structure tree steel section.
Loads a predefined section from the section library.
411
Load Settings
Settings/Settings
Loads settings from a file.
412
Local Undo
Tools/Edit
Local undo, undo for current mode only.
413
Lock/Unlock Layers
Modify/Layers
Locks/Unlocks layers.
414
Make Block
Drawings/Modify
Blocks entities.
415
Make Compatible With Structural/Architectural
Tools/Edit
Make architectural file compatible with structural.
416
Materials
Settings/Settings
Edit/create materials.
417
Mesh Wire Settings
Analysis and Design/Reinfrocement/Steel Bar Selection
Opens mesh wire settings.
418
Metal Slab
Draws metal slab.
419
Midpoint
Drawings/Snap
Snaps to midpoints of entities.
420
Mirror
Drawings/Modify
Takes symmetry.
421
Mirror Door/Window Label
Mirrors door/window labels.
422
Mirror X
Takes symmetry with respect to the X-axis.
423
Mirror Y
Takes symmetry with respect to the Y-axis.
424
Modal
Shows deformation modal visualization dialog page.
425
Modal Analysis Case
Adds a new modal analysis case.
426
Modify Truss Elements
It is located in the trusses toolbar.
Allow modify sub elements of truss.
427
Modulus of Subgrade Reaction
Shows concrete design in modulus of subgrade reaction visualization dialog page.
428
Moment 3-3 (Frame Results)
Shows frame moment 3-3 visualization dialog page.
429
Moment 3-3 (Purlin)
Structural Inspection/Purlin
Shows purlin moment 3-3 visualization dialog page.
430
Moment Resisting
Select moment resisting frame members.
431
Moment Resisting Frame
Steel/Design/Steel
432
Move
Drawings/Modify
Move.
433
Move Axis Label
Concrete/Axis/Axis
Moves axis label.
Steel/Axis/Axis
Modify/Entity Edit
434
Move Dimension Text
Moves dimension texts.
435
Move Raft Foundation Text
It is located in the Raft Foundation toolbar.
Moves raft foundation text.
436
Move Slab Text
Modify/Entity Edit/Slab
Moves slab text.
437
Move Stair Text
Moves stair text.
438
Creates multi stiffener plates.
439
Multi Stiffener Plate (Horizontal)
Creates horizontal multi stiffener plates.
440
Multiple Lines
Drawings/Primitives
Draws multiple lines.
441
Nearest Point
Drawings/Snap
Snaps to nearest points of entities.
442
New 2D Window
ideCAD logo
Creates a new, empty 2D drawing window.
443
New Project
ideCAD logo
Creates a new project.
444
New Layout Block-All Drawing
Creates a new layout block using all drawing.
445
New Layout Block-Circle
446
New Layout Block-Path Polygon
447
New Layout Block-Polygon
448
New Layout Block-Rectangle
449
New Material
Adds a new material.
450
Next Window
View/Window
Activates next window.
451
Noncomposite Castellated Beam
Display noncomposite castellated beam design results.
Steel/Design/Steel
452
Nonlinear Analysis Case
Adds a new nonlinear analysis case.
453
Notched Seating Connection
Connection/Ecperimentals/Continuous Beam Connection
Creates a notched seating connection.
454
NURBS
Drawings/Primitives
Draws NURBS curve.
455
Offset
Drawings/Modify
Offset.
456
OK
Finishes the current job.
457
Open
ideCAD logo
Opens a previously saved project.
458
Ortho
Drawings/Snap
Enters orthogonal drawing mode.
459
Outer Dimension
Drawings/Dimensions
Draws outer dimension.
460
Outer Dimension Settings
Opens outer dimension settings.
461
Overridden Elements (Concrete)
Shows concrete design in overridden elements visualization dialog page.
462
Overridden elements (Steel)
Shows steel design in overridden elements visualization dialog page.
463
Own Loads
Shows own loads visualization dialog page.
464
Page Down
Keyboard
Scrolls down the page in reports. Also shifts the viewpoint down in fly mode in the perspective view.
465
Page Up
Keyboard
Scrolls the page up in reports. Also shifts the viewpoint upwards in flight mode in the perspective view.
466
Pan
View/Zoom
Pans the window.
467
Panel Hydrostatic Load
Modify/Add Load
Adds shearwall water pressurized soil load.
468
Panel Lateral Load
Modify/Add Load
Adds shearwall lateral load.
469
Panel Soil Load
Modify/Add Load
Adds shearwall soil load.
470
Panel Vertical Load
Modify/Add Load
Adds shearwall vertical load.
471
Parallel Reference
Drawings/Snap
Parallel reference.
472
Parametric Hatch
Drawings/Hatch
Draws parametric hatch.
473
Paste
Drawings/Edit
Paste entities.
474
Paste Contour
Tools/Edit
Pastes contours.
475
Paste From File
Tools/File Sharing
Pastes entities from a .blk file.
476
Path
Drawings/Primitives
Draws path primitives.
477
Pattern Path
Drawings/Primitives
Draws pattern path.
478
PDF
Tools/Import/Export/Export
Exports To PDF.
ideCAD logo/Export
479
Pen Color
Settings/Settings
Opens pen and color settings.
480
Perform Steel Numbering
Drawings/Tools
Performs steel numbering.
481
Performance analysis results
Shows performance analysis results visualization dialog page.
482
Perpendicular Reference
Drawings/Snap
Perpendicular reference.
483
Perspective
View/Perspective
Changes view to perspective.
484
Pile (Concrete)
Concrete/Foundation
Draws piles.
485
Pile (Reinforcement)
Concrete/Design
Display the calculation results of the pile and the selected reinforcements.
Steel/Design
486
Pile (Report)
Concrete/Reports
Prepares pile general report.
Steel/Reports
487
Pile Drawings
Generates pile drawings.
Steel//Create Drawings/Concrete
Drawings//Create Drawings/Concrete
489
Pile Parameters
Opens pile parameters.
490
Pile Settings
Concrete/Foundation/Pile
Opens pile settings.
491
Plan Screenshot
Saves the screen image as a bitmap file.
ideCAD logo/Export
492
Plateau
Objects/Terrain
Draws plateau.
493
Plot
ideCAD logo
Plots your drawings.
494
Point Load
Modify/Add Load
Adds point load.
495
Point Raft Foundation Load
Draws point raft foundation load.
496
Point Slab Load
Concrete/Concrete
Draws point slab load.
497
Polar Array
Drawings/Edit
Creates copies of objects with rotation.
498
Polygon To Plate Section
Transforms primitive entities to plate section.
499
Polygon Column
Concrete/Concrete
Draws polygon column.
500
Polygonal Sheeting
Steel/Steel/Sheeting
Draws sheeting polygon.
501
Pool
Objects/Entities
Draws pool.
502
Pool Analysis
Performs pool analysis.
503
Pool Results
Structural Inspection/Shell Elements/Shell Results
Shows pool results visualization dialog page.
504
Pool Settings
Objects/Entities
Opens pool settings.
505
Post
Objects/Roof
Draws a post.
506
Preferences
Settings/Settings
Opens preferences.
507
Previous Window
View/Window
Activates previous window.
508
Project
Settings/Project Settings
Opens project settings.
509
Purlin
Objects/Roof
Draws purlins.
510
Purlin (Steel)
Steel/Steel
Draws steel purlin.
511
Purlin (Steel Design)
Concrete/Design
Display steel purlin design results.
Steel/Design
512
Purlin Connection
Creates a purlin connection.
513
Pushover (Report)
Reports/Nonlinear
Creates pushover report
514
Pushover Analysis
Performs pushover analysis.
515
Quad Stiffener Plate
Creates stiffener plates..
516
Quantity Report
Prepares quantity report.
Reports/Quantity
517
Radius Dimension
Drawings/Dimensions
Draws radius dimension.
518
Radius Dimension Settings
Opens radius dimension settings.
519
Raft
Concrete/Foundation
Draws raft foundation.
520
Raft Edge
Concrete/Foundation
Draws raft edge.
521
Raft Edge Settings
Concrete/Foundation/Raft Edge
Opens raft edge settings.
522
Raft Foundation (Reinforcement)
Concrete/Design
Display the calculation results of the raft foundation and the selected reinforcements.
Steel/Design
523
Raft Foundation (Report)
Concrete/Reports
Prepares raft foundation general report.
Steel/Reports
Reports/Foundation
524
Raft Foundation Detailed (Report)
Concrete/Reports/Concrete/Raft Foundation
Prepares raft foundation detailed general report.
Steel/Reports/Concrete/Raft Foundation
Reports/Foundation/Raft Foundation
525
Raft Foundation Hole
Draws raft foundation hole.
526
Raft Foundation Parameters
Opens raft foundation parameters.
527
Raft Foundation Results
Shows raft foundation results visualization dialog page.
528
Raft Foundation Settings
Opens raft foundation settings.
529
Rafter
Objects/Roof
Draws rafters.
530
Raster Image
Drawings/Primitives
Places a raster image file onto the drawing.
531
Rebar Numbering Settings
Drawings/Tools
Sets rebar numbering options.
532
Rectangle
Drawings/Primitives/Multiple Lines
Draws a rectangle.
533
Rectangle Line
Draws a rectangle.
534
Rectangular Column to Circular
Converts rectangular columns to circular columns.
535
Rectangular Wall
Draws 4 walls as a rectangle.
536
Redo
Tools/Edit
Redo.
537
Reinforcement Shearwall
Concrete/Concrete/Shearwalls
Draws reinforcement shearwall.
538
Remove Concrete Calculation Line
Removes concrete calculation line.
539
Remove from Selection Group
Right Click Menu
Removes objects from previously created groups.
540
Remove Nodule
It is located in the space truss toolbar.
Removes a nodule from space truss.
541
Remove Point
Removes an existing point on hatch.
542
Remove Stair Concrete Calculation Line
Removes stair concrete calculation line.
543
Remove Unused Sections
Removes unused steel sections.
544
Render
Tools/Render
Renders active view.
View/View
545
Repeat Last Command
Right click menu
Repeats last command.
546
Reset Dimension Texts
Resets dimension text displacements.
547
Reset Jacket Edge
Resets column jacket edge thickness.
548
Reset Settings
Settings/Settings
Resets settings.
549
Response Spectrum Case
Adds a new response spectrum case.
550
Response Spectrum Function
Adds a new response spectrum function.
551
Retaining Wall (Concrete)
Concrete/Foundation
Draws retaining walls.
552
Retaining Wall (Reinforcement)
Display the calculation results of the retaining wall and the selected reinforcements.
553
Retaining Wall (Report)
Prepares retaining wall report.
Reports/Foundation
554
Retaining Wall Analysis
Performs retaining wall analysis.
555
Retaining Wall Drawings
Prepares retaining wall drawings.
556
Retaining Wall Parameters
Opens retaining wall concrete settings.
557
Revision Cloud
Drawings/Primitives
Draws revision cloud.
558
Rib Drawings
Rib drawings.
559
Ribbed Slab (Report)
Concrete/Reports/Concrete/Slab
Prepares ribbed slab general report.
Steel/Reports/Concrete/Slab
Reports/Slab/Slab
560
Ribbed-Waffle Slab Parameters
Opens ribbed-Waffle slab parameters.
561
Ribbed Slab Reinforcements
Display the calculation results of the ribbed slab and the selected reinforcements.
562
Right
View/Perspective
Changes view to right.
563
Rigid on Both Axis Base Plate
Connection/Experimental/Simple Base Plate
Creates a rigid on both axis base plate connection.
564
Rigid on Strong Axis Base Plate
Creates a rigid on strong axis base plate connection.
565
Rigidity Reductions
Shows concrete design in rigidity reduction visualization dialog page.
566
Roof
Objects/Roof
Draws roof.
567
Roof Details
Opens the roof details toolbar.
568
Roof Hole
Objects/Roof
Draws roof hole.
569
Roof Plan Drawings
Concrete/Creating Drawings/Steel
Draws steel roof plan.
Steel/Creating Drawings/Steel
Drawings/Creating Drawings/Steel
570
Roof Plane
Objects/Roof
Draws roof plane.
571
Roof Window
Draws roof window.
572
Rotate
Drawings/Modify
Rotate.
573
Rotate Building
Tools/Tools
Rotates the building.
574
Rotate Node
Drawings/Modify
Rotates node.
575
Round Plate Tube Base Plate
Creates a round plate tube base plate connection.
576
SAP2000.s2k
Exports a SAP2000 database file.
ideCAD logo/Export
577
Sagrod for Roof Purlins
Steel/Steel/Sagrod
Draws top sag rod connection between 2 roof purlins.
578
Sagrod on Single Purlins
Steel/Steel/Sagrod
Draws sag rod on single purlins.
579
Sagrod
Steel/Steel
Draws sag rod on purlin group.
580
Save
ideCAD logo
Saves current project.
581
Save As
ideCAD logo
Save current project with a new name.
582
Save Compact
ideCAD logo
Saves compresed project file.
583
Save Old Version
ideCAD logo
Saves old version project file.
584
Save Settings
Settings/Settings
Saves settings to a file.
585
Save Stair
Saves stair.
586
Scaffolding Drawings
Creates scaffolding drawings.
587
Scaffolding Macro
Creates scaffolding.
588
Scale
Drawings/Modify/Scale by Reference
Scales entities.
589
Scale by Reference
Drawings/Modify
Scales entities by reference.
590
Creates a seating support connection.
591
Seating Truss Connection
Creates a seating truss connection.
592
Seating Weld Connection
Connection/Experimental/Welded Connection
Creates a seating weld connection.
593
Secondary Beam (Steel)
Steel/Steel
Draws secondary beam.
594
Secondary Beam (Steel Design)
Display secondary beam design results.
Steel/Design/Steel
595
Secondary stair deformation.
596
Opens the section library dialog.
597
Section / Elevation List
Objects/Section
Edit and generate sections and elevations.
Tools/Generate
598
Section Elevation
Drawings/Dimensions
Draws section elevation.
599
Section Elevation Settings
Drawings/Dimensions/Section Elevation
Opens section elevation settings.
600
Section Line
Objects/Section
Draws section line.
Drawings/Tools
601
Seismic Isolators
Settings/Settings
Opens the seismic isolators settings.
602
Seismic Isolators (Report)
Prepares seismic isolators reports.
603
Select All
Drawings/Edit
Selects all entitites.
604
Select Analysis Part
Steel/Steel/Purlin
Select purlins to add analysis.
605
Select Entity In All Stories
Drawings/Edit
Selects entity in all stories.
606
Select Entities Using Material
Right click menu in structure tree materails part.
Selects objects in which the material is used.
607
Select Entities Using Section
Right click menu in structure tree section part.
Selects objects in which the sections is used.
608
Select Group of Objects
Selects the created object group.
609
Select Point Details
Select connections to add point details.
610
Select Reports
Concrete/Reports
Report selection.
Steel/Reports
Reports/Summary
611
Select Similars
Selects elements with similar properties
612
Select Terrain and Child Entities
Selects terrain and child entities.
613
Semi Rigid
Use semi rigid diaphragms.
614
Set Auto Elevation
Set auto elevation.
615
Set Cantilevers
Modify/Entity Edit/Beam-Footing
Sets cantiever beams and footings.
616
Set Dome Restraints
It is located in the dome toolbar.
Sets dome restraints.
617
Set Entity Direction
Sets beam
618
Set Entity Settings
Sets default settings to selected entities.
Drawings/Modify
619
Set Hatch Reference
Modify/Entity Edit
Sets hatch reference point.
620
Set Local CS
Drawings/Snap
Sets new local coordinate system.
621
Set Pool Cantilever Slab Properties
Modify/Entity Edit/Pool
Set pool cantilever slab properties.
622
Set Pool Surface Properties
Set pool surface properties.
623
Set Pool Surface Slope
Set pool surface slope.
624
Set Pool Wall Properties
Set pool wall properties.
625
Set Selection
Sets currently selected entities.
626
Set Short Columns
Sets short columns.
627
Set Stair Boundary Conditions
Sets boundary conditions of stairs.
628
Set Steel Delta
It is located in the steel column toolbar.
Sets steel element delta.
629
Set Trim Algorithm
Modify/Entity Edit
Sets entity trim algorithm.
630
Set Typical Rib
Concrete/Concrete
Sets typical ribs of ribbed-waffle slabs.
631
Set Vault Restraints
It is located in the vault toolbar.
Sets vault restraints.
632
Shear 2-2
Shows frame shear 2-2 visualization dialog page.
Steel/Structural Inspection/Moment 3-3
633
Shearwall (Concrete)
Concrete/Concrete
Draws shearwall.
634
Shearwall (Reinforcement)
Display the calculation results of the shearwall and the selected reinforcements.
635
Shearwall (Report)
Prepares shearwall general report.
Reports/Concrete
636
Shearwall Core Reinforcements
Display the calculation results of the core shearwall and the selected reinforcements.
637
Shearwall Drawings
Prepares shearwall drawings.
638
Shearwall Moment 2-2
Structural Inspection/Shearwall/Axial Force
Shows shearwall moment 2-2 visualization dialog page.
639
Shearwall Moment 3-3
Shows shearwall moment 3-3 visualization dialog page.
640
Shearwall Parameters
Opens shearwall parameters.
641
Shearwall Shear 2-2
Shows shearwall shear 2-2 visualization dialog page.
642
Shearwall Shear 3-3
Shows shearwall shear 3-3 visualization dialog page.
643
Shearwall Thickness
Shows concrete design in shearwall thickness visualization dialog page.
644
Shearwall To Beam
Converts shearwalls to beams.
645
Shearwall to Column
Converts shearwalls to columns.
646
Shearwall Settings
Opens shearwall settings.
647
Sheeting
Steel/Steel
Draws sheeting over purlins.
648
Sheeting Between Elements
Draws sheeting between two elements.
649
Sheeting Own Loads
Shows steel design in sheeting own loads visualization dialog page.
650
Sheeting Snow Loads
Shows steel design in sheeting snow loads visualization dialog page.
651
Shell Dome/Vault
Shows shell dome/vault visualization dialog page.
652
Shell Results
Shows shell solved with structure visualization dialog page.
653
Shell Slab
Shows shell slab visualization dialog page.
654
Shell Stair
Shows shell stair visualization dialog page.
655
Show Coordinate Box
View/Windows
Show coordinate box.
656
Show Safe Frame
Right click menu in perspective.
Shows rendering limits before rendering.
657
Show Structure Tree
View/Windows
Show structure tree.
658
Show Toolbars
View/Windows
Show toolbars.
659
Show/Hide Dimension Text
Shows/hides dimension text.
660
Show/Hide Layers
Modify/Layers
Show/hide entity layers.
661
Show/Hide Nodes
View/View
Shows/hides nodes
662
Show/Hide Railing
Shows/hides railings.
663
Simple Base Plate
Connection/Esperimentals
Creates a simple base plate connection.
664
Single Angle Connection
Creates a single angle connection.
665
Single Footing (Concrete)
Concrete/Concrete
Draws single footing.
666
Single Footing (Reinforcement)
Display the calculation results of the single footing and the selected reinforcements.
667
Single Footing (Report)
Prepares single footing report.
668
Single Footing Drawings
Prepares single footing drawings.
669
Single Footing Parameters
Opens single footing parameters.
670
Single Footing Report
Reports/Concrete
671
Single Footing Settings
Concrete/Foundation/Single Footing
Opens single footing settings.
672
Single Part Drawings
Draws steel single part.
673
Creates a single plate connection.
674
Single Plate Seating Connection
Creates a single plate seating connection.
675
Single Purlin
Steel/Steel/Purlin
Draws single steel purlin.
676
Single Secondary Steel Beam
Steel/Steel/Secondary Beam
Draws single secondary beam.
677
Single-Part And Assembly (Report)
Creates single-part and assembly reports.
Steel/Reports/Steel
Reports/Steel
678
Slab (Concrete)
Concrete/Concrere
Draws slab.
679
Slab (Reinforcement)
Concrete/Design/Concrere
Display the calculation results of the slab and the selected reinforcements.
680
Slab (Report)
Prepares slab general report.
Reports/Slab
681
Slab Analysis
Does slab analysis.
682
Slab Coating (Concrete)
Shows concrete design in slab coating visualization dialog page.
683
Slab Coating Loads (Steel)
Shows steel design in slab coating visualization dialog page.
684
Slab Dead Loads (Steel)
Shows steel design in slab total dead loads visualization dialog page.
685
Slab Detailed (Report)
Prepares slab detailed general report.
Reports/Slab/Slab
686
Slab Edge
Concrete/Concrete
Draws slab edge.
687
Slab Edge (Steel)
Draws slab edge.
688
Slab Edge Settings
Opens slab edge settings.
689
Slab Hole
Concrete/Concrete
Draws slab hole.
690
Slab Live Loads (Concrete)
Shows concrete design in slab live loads visualization dialog page.
691
Slab Live Loads (Steel)
Shows steel design in slab live loads visualization dialog page.
692
Slab Loads (G)
Shows slab loads acting on elements (G) visualization dialog page.
693
Slab Loads (Q)
Shows slab loads acting on elements (Q) visualization dialog page.
694
Slab Parameters
Opens slab parameters.
695
Slab Settings
Opens slab settings.
696
Slab With MW
Display the calculation results of the slabs with mesh wire and the selected reinforcements.
Analysis and Design/Design/Concrete
697
Slab coating loads
Structural Inspection//Input/Steel
698
Slab Thickness (Concrete)
Shows concrete design in slab thickness visualization dialog page.
699
Slab thickness (Steel)
Shows steel design in slab thickness visualization dialog page.
700
Slab Total Death Loads (Concrete)
Shows concrete design in slab total death load visualization dialog page.
701
Sloping Flat
Steel/Macro/Truss
Draws Sloping Flat Truss.
702
Sloping Vault
Steel/Macro/Truss
Draws Sloping Vault Truss.
703
Snap to Grid
Drawings/Snap
Snap to grid.
704
Snap to Nodes
Drawings/Snap
Snap to nodes.
705
Snow Loads
Shows snow loads visualization dialog page.
706
Soil Layers
Settings/Settings
Edit / create soil layers.
707
Soil Loads
Shows soil loads visualization dialog page.
708
Solid
Changes view detail to solid with edges.
709
Solid with Edges
View/View
710
Space
Keyboard
Moves the cursor to horizontal, vertical, and free axis drawing positions on axes. Changes the offset in commands such as wall, column, beam, shearwall. Skips a name in object labeling. Changes the insertion point in commands such as stair, library.
711
Space Purlin
Steel/Steel/Purlin
Draws space purlin.
712
Space Purlin (Steel Design)
Display space purlin design results.
Steel/Design/Steel
713
Space Purlin (Report)
Creates space purlin report.
Steel/Reports/Steel
Reports/Steel
714
Space Truss (Steel Design)
Display space truss design results.
Steel/Design/Steel
715
Space Truss (Report)
Creates space truss report.
Steel/Reports/Steel
Reports/Steel
716
Spacer Plate Connection
Creates a spacer plate connection.
717
Splice Connection
Connection/Connection/Joining Plates Connection
Creates a splice connection.
718
Stair (Concrete)
Concrete/Concrete
Draws stair.
719
Stair (Steel)
Steel/Macro
Creates steel stair.
720
Stair (Reinforcement)
Display the calculation results of the stair and the selected reinforcements.
721
Stair Analysis
Does stair analysis.
722
Stair Drawings
Generates stair drawings.
723
Stair General Report
Prepares stair general report.
Reports/Concrete
724
Stair Parameters
Opens stair parameters.
725
Stair Settings
Opens stair settings.
726
Static Linear Load Case
Adds a new load case.
727
Stay Connection
Connection/Experimentals/Stiffened Shear Plate Connection
Creates a stay connection.
728
Stay Connection (Secondary Beam)
Craetes a stay connection (secondary beam).
729
Steel (Drawings)
730
Steel All Failures
Shows steel design out all failures visualization dialog page.
731
Steel Axial Ratios
Structural Inspection/Design/Steel
Shows steel design axial ratios visualization dialog page.
732
Steel Axial failure
Structural Inspection/Output/Steel All Failures
Shows steel design out axial failure visualization dialog page.
733
Steel Bar Selection
Analysis and Design/Reinforcement
Steel bar selection.
734
Steel Beam (Report)
Creates steel beams report.
Steel/Reports/Steel
Reports/Steel
735
Steel Bending Capacities - Major Axis
Shows steel design in bending capacities (major axis) visualization dialog page.
736
Steel Bending capacities - minor axis
Shows steel design in bending capacities (minor axis) visualization dialog page.
737
Steel Castellated beam design ratios
Shows steel design castellated beam ratios visualization dialog page.
738
Steel Column (Report)
Creates steel columns report.
Steel/Reports/Steel
Reports/Steel
739
Steel Column 2 Points
Steel/Steel/Columns
Draws steel column.
740
Steel Composite beam design ratios
Shows steel design composite beam ratios visualization dialog page.
741
Steel Connection D/C ratios
Shows steel design connection D/C ratios visualization dialog page.
742
Steel Connection failures
Shows steel design out connection failures visualization dialog page.
743
Steel Deflection Failure
Shows steel design out deflection failure visualization dialog page.
744
Steel Drawings
Creates steel drawings.
745
Steel Hand Rail Macro on Arc
Steel/Macro/Hand Rail
Creates steel hand rail on arc.
746
Steel Hand Rail Macro on Line
Creates steel hand rail on line.
747
Steel Joist
Steel/Steel/Purlin
Draws steel joist.
748
Space Joist (Steel Design)
Display steel joist design results.
Steel/Design/Steel
749
Steel Joist (Report)
Creates steel joists report.
Steel/Reports/Steel
Reports/Steel
750
Steel Numbering Settings
Drawings/Tools
Opens steel numbering settings.
751
Steel PMM Failure
Shows steel design out pmm failure visualization dialog page.
752
Steel PMM Ratios
Shows steel design pmm ratios visualization dialog page.
753
Steel Purlin (Report)
Creates steel purlins report.
Steel/Reports/Steel
Reports/Steel
754
Steel Secondary Beam (Report)
Creates steel secondary beams report.
Steel/Reports/Steel
Reports/Steel
755
Steel Shear capacities - major axis
Shows steel design in shear capacities (major axis) visualization dialog page.
756
Steel Shear capacities - minor axis
Shows steel design in shear capacities (Minor axis) visualization dialog page.
757
Steel Shear failure
Shows steel design out shear failure visualization dialog page.
758
Steel Shear ratios - major axis
Shows steel design shear ratios (major axis) visualization dialog page.
759
Steel Shear ratios - minor axis
Shows steel design shear ratios (minor axis) visualization dialog page.
760
Steel Tie
Steel/Steel/Purlin
Draws steel tie.
761
Creates a stiffened end plate connection.
762
Creates a stiffened shear plate connection.
763
Stirrup
Draws stirrup.
764
Story
Arrange stories in the project.
765
Story Copy
Copies all entities from a story to another story.
Tools/Edit
Drawings/Edit
766
Story Forces (Report)
Concrete/Reports
Prepares story forces report.
Steel/Reports
767
Story List
Display story list.
Tools/Edit
View/Windows
768
Story Parameters
Opens story parameters.
769
Story Settings
770
Stretch Node
Drawings/Modify
Stretch node.
771
Strip (Concrete)
Concrete/Foundation
Draws multiple strip footings.
772
Strip Footing Report
Prepares strip footing general report.
Reports/Reports/Concrete
773
Strip Footing Settings
Concrete/Foundation/Strip
Opens strip footing settings.
774
Strip Foundation (Reinforcement)
Display the calculation results of the strip foundation and the selected reinforcements.
775
Strip Foundation Drawings
Prepares strip foundation drawings.
776
Strip Foundation Parameters
Opens strip foundation parameters.
777
Structural Design Mode
View/Mode
Enters structural design mode.
778
Structural Section
Drawings/Tools/Section Line
Draws structural section line.
779
Structure Risk Analysis
Performs risk analysis of the structure.
780
Structure Summary (Report)
Prepares structure summary report.
Reports/Summary
781
Strut
Objects/Roof
Draws a strut.
782
Stub
Creates stub.
783
Sub-basement Shearwall
Creates sub-basement shearwalls.
784
Sub Region
Objects/Terrain
Draws sub region.
785
Switch Windows
Drawings/Window
Returns to last story window.
786
T Plate Connection
Creates a T plate connection.
787
T-Beam Width
Shows concrete design in t-beam widths visualization dialog page.
788
TBDY 2018 Seismic Parameters Report
Prepares TBDY 2018 seismic parameters report.
789
TBDY Non-Structural Element Forces Report
Reports/EQ Code
Generate non-structural element forces report.
790
TBDY Seismic Joint Thickness Report
Reports/EQ Code
Generate seismic joint thickness report.
791
TS EN 1991-1-4 Wind Loads
Creates wind loads report according to TS EN 1991-1-4.
792
Target Workplane
View/Workplane
Creates a free workplane using existing objects.
793
Tangent
Drawings/Snap
Draws tangents.
794
Tekla.dmp
Exports project to TEKLA software.
ideCAD logo/Export
795
Terrain Polygon
Objects/Terrain
Draws terrain polygon.
796
Terrain Settings
Objects/Terrain/Terrain Polygon
Opens terrain settings.
797
Text
Drawings/Text
Draws text.
798
Text Settings
Drawings/Text/Text
Opens font settings.
799
Time History Case
Adds a new time history case.
800
Time History Function
Adds a new time history function.
801
Tip of the Day
ideCAD logo/Help
Shows tip of the day.
802
Toggle Axonometric View
Right click menu
Switches between perspective and axonometric views.
803
Toggle Fullscreen
View/Window
Resizes the view to full screen.
804
Top
View/Perspective
805
Transform To Ribbed Slab
Concrete/Concrete
Transforms a slab to a ribbed slab.
806
Transform To Waffle Slab
Concrete/Concrete
Transforms a slab to a waffle slab.
807
Transparent Story
Settings/Settings
Opens transparent story settings dialog.
808
Trapezoid Sloping Left
Steel/Macro/Truss
Draws Trapezoid Sloping Left Truss.
809
Trapezoid Sloping Right
Steel/Macro/Truss
Draws Trapezoid Sloping Right Truss.
810
Trapezoid Sloping Symmetric
Steel/Macro/Truss
Draws Trapezoid Sloping Symmetric Truss.
811
Trapezoid Slopping Asymmetric
Steel/Macro/Truss
Draws Trapezoid Slopping Asymmetric Truss.
812
Trapezoid Type 1
Steel/Macro/Truss
Draws Trapezoid Type 1 Truss.
813
Trapezoid Type 2
Steel/Macro/Truss
Draws Trapezoid Type 2 Truss.
814
Trapezoid Vault
Steel/Macro/Truss
Draws Trapezoid Vault Truss.
815
Trapezoidal Load
Modify/Add Load
Adds trapezoidal load.
816
Triangular Asymmetric
Steel/Macro/Truss
Draws Triangular Asymmetric Truss.
817
Triangular Sloping Left
Steel/Macro/Truss
Draws Triangular Sloping Left Truss.
818
Triangular Sloping Right
Steel/Macro/Truss
Draws Triangular Sloping Right Truss.
819
Triangular Symmetric
Steel/Macro/Truss
Draws Triangular Symmetric Truss.
820
Trim
Drawings/Modify
Line cuts primitive objects such as arcs to another line or arc.
821
Trim Column
Trims column edges with an axis or beam.
822
Trimmer
Objects/Roof
Draws a trimmer.
823
Truss (Steel)
Steel/Macro
Draws Custom Truss.
824
Display truss design results.
Steel/Design/Steel
825
Truss (Report)
Creates truss report.
Steel/Reports/Steel
Reports/Steel
826
Truss Connection
Creates a truss connection.
827
Truss Drawings
Concrete/Create Drawings/Steel
Draws steel truss.
Steel/Create Drawings/Steel
Drawings/Create Drawings/Steel
828
Tube Base Plate
Connection/Experimentals/Simple Base Plate
Creates a tube base plate connection.
829
Undo
Tools/Edit
Undo.
830
Uniform Area Load
Modify/Add Load
Adds uniform area load.
831
Uniform Load
Modify/Add Load
Adds unifom load.
832
Unstiffened Seated Connection
Creates an unstiffened seated connection.
833
Update Layout Block
Updates linked layout blocks.
834
Update Library Elevation
Update library elevation.
835
Use Distance
Use distance.
836
Use Dio Reference
Use dio as reference.
837
User Defined Hatch
Drawings/Hatch
Draws user defined hatch.
838
User Loads
Shows user loads visualization dialog page.
839
Vault (Concrete)
Objects/Roof
Draws vault.
840
Vault (Steel)
Steel/Macro/Truss
Draws vault truss.
841
Vault Settings
Objects/Roof/Vault
Opens vault settings.
842
Vertical Workplane
View/Workplane/Target Workplane
Creates a vertical workplane.
843
View
Settings/Settings
Opens view settings.
844
Viewport Configuration
View/Window
Display view configuration options.
845
Waffle Drawings
Preapares waffle drawings.
846
Waffle Slab (Report)
Prepares waffle slab general report.
847
Waffle Slab Reinforcement
Display the calculation results of the waffle slab and the selected reinforcements.
Reports/Slab/Slab
848
Wall
Concrete/Wall
Draws wall.
849
Wall (Loads)
Shows wall loads visualization dialog page.
850
Wall Loads (Concrete)
Shows concrete design in wall loads visualization dialog page.
851
Wall Loads (Steel)
Shows steel design in wall loads visualization dialog page.
852
Wall Settings
Concrete/Wall/Wall
Opens wall settings.
853
Weld Electrodes
Define weld electrodes.
Steel/Design/Steel
Analysis and Design/Design Parameters/Steel
854
Welded Box/Tube Connection
Creates a welded box/tube connection.
855
Welded Connection
Creates Welded Connection.
856
Welded Flange Plate Connection
Connection/Connection/Bolted Flange Plate Connection
Creates a welded flange plate connection.
857
Welded Web Connection
Creates a welded web connection.
858
Well Foundation (Concrete)
Concrete/Foundation
Draws well foundations.
859
Well Foundation (Reinforcement)
Display the calculation results of the well foundation and the selected reinforcements.
860
Well Foundation (Report)
Preapares well foundation report.
Reports/Foundations
861
Well Foundation Analysis
Concrete/Analysis/Analysis Design
Performs well foundation analysis.
Steel/Analysis/Analysis Design
Analysis and Design/Analysis/Analysis Design
Structural Inspection/Analysis/Analysis Design
862
Well Foundation Drawings
Preapares well foundation drawings.
863
Well Foundation Parameters
Opens well foundation concrete settings.
864
Wind Connection
Creates a wind connection.
865
Wind Loads
Shows wind loads visualization dialog page.
866
X (Coordinate Box)
Coordinate Box
Enters the X coordinate box. X coordinate is entered.
867
Y (Coordinate Box)
Coordinate Box
Enters the Y coordinate box. Y coordinate is entered.
868
Zoom
View/Zoom
Zooms the window.
869
Zoom Extents
View/Zoom
Zooms to the extents of the drawings.
870
Zoom Selection
View/Zoom
Zoom selection.
871
Zoom Window
View/Zoom
Zoom into a rectangular window.
872
Zoom In (+)
Keyboard
Zooms in.
873
Zoom Out (-)
Keyboard
Zooms out.
