The layer of existing objects is changed with the "Change Entity Layer" command.
To change the object layer;
Select the object whose layer you want to change.
Menu Modify/Layers/Change Entity Layers, click the icon.
The Change Entity Layers dialog will open. From here, select the new layer of your object and click the OK button.
The layer of your object will change.
