With the Library Settings command, settings such as library type selection, dimensions, elevation and material selection are accessed.
Location of Library Settings Dialog
After running the library command, the library that appears on the screen is in the auxiliary toolbar.
You can also access it under the ribbon menu Home tab, Entities title in the architectural program.
Library Tab
Object list
Furnishing elements are gathered in the library settings dialog and organized under folders according to their types. You can choose any furnishing element here. |
X length/X percent The X dimension (width) of the selected element. Replaceable. The change made is given as a percentage based on design measures. If desired, object dimensions can be changed by entering the percentage value. |
Y length/Y percent The Y dimension (length) of the selected element. Replaceable. The change made is given as a percentage based on design measures. If desired, object dimensions can be changed by entering the percentage value. |
Z length/Z percent The Z dimension (height) of the selected element. Replaceable. The change made is given as a percentage based on design measures. If desired, object dimensions can be changed by entering the percentage value. |
Same ratio It is used for automatic changing of dimensions in any direction of the library, at the same rate in the other direction. |
ID Includes the name of the selected library. Replaceable. |
Color The drawing color of the library object in the plan. When the color box is clicked, the appropriate color is selected from the window that opens. |
Elevation The vertical distance (level) of the lower face of the wall (wall base) measured from the floor base is entered. The vertical distance (elevation) of the selected element measured from the floor is entered. |
Angle The angle (degrees) of the selected element in the drawing area. As the furnishing is drawn, its angle changes with the movement of the mouse. If wanted, the object angle can be changed here. |
Pattern It is the pattern type valid for the library. When checked, the library object appears in the plans with hatching. When the search box is clicked, the appropriate pattern type is selected from the window that opens. |
Face count Shows the count of surfaces the selected object has. It cannot be intervened. |
Material Clicking the down arrow buttons to the right of the boxes opens the list of available materials for the relevant library. Any of these materials can be clicked with the mouse and selected. |
Description
Includes the description of the selected object. It cannot be intervened. |
Plan view
The plan drawing of the selected object is given. |
Draw as a bounding box in 3D By marking, libraries are shown in 3 dimensions only as a frame, not detailed. You can check this option to increase the performance of working on the project. |
Cut holes in hatch When the library is placed on hatching, this option is checked if it is wanted to clean (trim) the hatch under the library. |
Show materials in 3D preview By marking, libraries selected in the preview preview are displayed on the assigned textures. |
Always face to camera Silhouettes and library objects are automatically turned perpendicular to the camera without having to be placed perpendicular to the camera. |
Perspective preview
Three-dimensional view of the selected object is included. If the mouse is moved while holding down the left mouse button, the object will be rotated. If the mouse is moved by clicking the right mouse button, the object can be zoomed in and out. In this way, it is possible to examine the object in three dimensions. |
Components Tab
Click the Add Building Component button.
In this dialog, click the folder related to the material from the list on the left. Choose the material you want to use.
In the usage section
Following are the lines that appear in the proportion list according to the library object and material size.
Library |
Measure |
Listed |
Explanation |
Constant |
Independent |
Length |
Independent |
X lenght |
It means that the length of the material will be found by multiplying the length measure found while defining the material and the X length value of the library. |
Y lenght |
It means that the length of the material will be found by multiplying the length measure found while defining the material and the Y length value of the library. |
Z lenght |
It means that the length of the material will be found by multiplying the length measure found while defining the material and the Z length value of the library. |
Area |
Independent |
It means that the area measure found while defining the material will be used exactly as the field value. |
Volume |
Independent |
The volume measurement found when defining the material will be used exactly as the volume value. |
Count |
Independent |
The number count found while defining the material will be used exactly as the number value. |
Count |
The count measure found while defining the material will be used exactly as the number value. |
