How do I know if there is overlapping of elements?
If overlapping elements are defined in the program, problems may arise in the analysis model and design. For this reason, it is necessary to pay attention to the overlapping element definitions.
Overlapping Elements
  1. Overlapping elements in the program can be done with the Check Geometry in the menu.
  2. When you click on the Check Geometry, the elements defined on top of each other will appear in the program.
