The Edit Label Text command changes the label text content.
Location of the Edit Text Label Command
Select the label whose text you want to change, click the right button of the mouse and click the Edit Label Text line from the menu that opens.
In the Architectural Program
You can access it under the Ribbon menu Modify tab, Entity Edit title.
In the Structural Program
Select the label whose text you want to change.
Click the Edit Label Text icon in the ribbon menu or click the right button of the mouse and click the Edite Label Text line from the drop-down list .
Type the text you want in the dialog that opens.
Click the OK button. The text will change.
Before edit label text
Selecting the label and entering the edit label text command
Editing the label text
After edit label text
