How does ideCAD calculate the flexural buckling limit state for compression strength according to AISC 360-16?
The compression strength of steel elements is calculated automatically according to AISC 360-16.
The nominal compressive strength limit states of flexural buckling, torsional buckling, and flexural-torsional buckling are controlled automatically according to AISC 360-16.
Fcr : Critical stress
Fe : Elastic buckling stress determined according to Equation E3-4,
Fy : Specified minimum yield stress of the type of steel being used,
K : Effective length factor
Lc : Effective length of the member, (= KL)
Pn : Nominal compressive strength, kips (N)
r : Radius of gyration
Flexural Buckling Members without Slender Elements §E3
This section applies to non slender-element compression members, as defined in AISC Section B4.1, for steel elements in axial compression.
The nominal compressive strength, Pn, is determined based on the limit state of flexural buckling:
The critical stress, Fcr, is determined as follows:
When
When
