How does ideCAD define T-beam effective width according to ACI 318-19?
In T-Beam construction, the effective flange width is determined and applied automatically.
Notation
bf = effective flange width, in.
sw = clear distance between adjacent webs, in.
In nonprestressed T-Beam monolithic concrete construction, the effective flange width, bf, equals the beam width bw, plus an effective overhanging flange width in accordance with ACI Table 6.3.2.1.
Flange location |
T-beam overhanging flange width |
Each side of the web |
One side of the web |
h is the slab thickness and sw is the clear distance to the adjacent web.
According to ACI 6.3.2.2, isolated nonprestressed T-beams to provide additional compression area should have a flange thickness greater than or equal to 0.5bw and an effective flange width less than or equal to 4bw.
