For A22 (BYS)> = 4 condition is not met.
The Complete Message:
For A22 structural system type, Building Height Class (BYS)> = 4 condition is not met in (X / Y) direction.
In TBDY 2018 Table 4.1, Building Height Class (BYS)> = 4 limit is set for A22 structural system. The program gives a warning because the building carrier system A22 is selected and the BYS> = 4 condition is not met.
Table 3.3 - Building Height Classes and Building Height Ranges Defined According to Earthquake Design Classes:
Building Height Ranges Defined According to Building Height Classes and Earthquake Design Classes [m]
DTS = 1, 1a, 2, 2a
DTS = 3, 3a
DTS = 4, 4a
BYS = 1
HN > 70
HN > 91
HN >105
BYS = 2
56 <HN ≤ 70
70 <HN ≤ 91
91<HN ≤105
BYS = 3
42 <HN ≤ 56
56 <HN ≤ 70
56 <HN ≤ 91
BYS = 4
28 <HN ≤ 42
42 <HN ≤ 56
BYS = 5
17.5 <HN ≤ 28
28 <HN ≤ 42
BYS = 6
10.5 <HN ≤17.5
17.5 <HN ≤ 28
BYS = 7
7 <HN ≤10.5
10.5 <HN ≤17.5
BYS = 8
H N ≤ 7
H N ≤10.5
Solution:
  • If Building (BYS) = 3 , it can be used for carrier system types A11, A12, A13, A14, A15 . The selection of the carrier system type can be changed with the Analysis Settings / TBDY 2018 Earthquake Code wizard by changing the appropriate carrier system, ductility level.
  • If Building (BYS) = 2 , it can be used for carrier system types A12, A13, A14, A15 . The choice of carrier system type can be changed with the Analysis Settings / TBDY 2018 Earthquake Code wizard by going to the appropriate carrier system changes.
  • If the building BYS = 1 , the buildings specified in the article 3.3.2.2 of TBDY 2018 will be classified as high-rise buildings according to Section 13, according to the condition , the building should be designed according to the principles given in Section 13 of TBDY.
