Property Polygon Definition
With the define property polygon command, the property is automatically created by entering the X/Y coordinate and setback distance values ​​in the boundary survey into the table.
Location of Define Property Polygon Command
You can access it under the Ribbon menu Tools tab Floor Area Calculation heading.
  • Click the Define Property Polygon icon.
  • Click the Yes button for the question "Would you like to define property polygon by manually entering coordinates to table?"
  • The property polygon dialog will open.
  • Click the Add New Point button.
  • Let's enter our points using the coordinate values ​​in the attached table.
No
Y
X
1
-10
-10
2
24
-10
3
24
20
4
-10
20
  • The first line will be created. Enter the x values ​​in the boundary survey into the y line and the y values ​​into the x line.
  • Create your second line by clicking the add new point button.
  • By following the schematic drawing in the boundary survey, enter the x values ​​of your second point into the y line and the y values ​​into the x line.
  • A preview of your boundary of property will begin to appear in the property polygon dialog.
  • Complete your points by following the schematic drawing in the boundary survey.
  • Follow the property polygon dialog preview section and enter the relevant setback distance in the offset distance column.
  • When you click the OK button, a preview of your property border and north arrow will be created.
  • Place it by clicking on the desired point. Your property borders are created.
Entering coordinate values ​​for the first point
Entering coordinate values ​​for the second point
Entering coordinate values ​​for the third point
Entering coordinate values ​​for the fourth point
Entering 3m as the setback distance in the offset distance column
Creating a preview of the property boundary
Formation of property border
