Defining a Box/Tube Seating Connection
With the Box/Tube Seating Connection command, column-beam connection is defined.
Location of the Box/Tube Seating Connection Command
  • From the Connection menu, click on the Box/Tube Seating Connection icon.
  • The box/tube seating connection settings dialog will open.
Location of the Box/Tube Seating Connection Settings Dialog
Type Tab
Type
Gusset and stffener plate selections are made for the combination.
Schematic drawing
Connection is shown on the schematic drawing.
Preview
Cap and Stiffener Plates Tab
Beam cap plate
The beam cap plate is determined by entering the value. The values ​​to be entered are shown in the schematic drawing.
Beam stiffener plate
Beam stiffener plate is determined by entering the value. The values ​​to be entered are shown in the schematic drawing.
Column cap plate
Column cap plate is determined by entering the value. The values ​​to be entered are shown in the schematic drawing.
Schematic drawing
Preview
Chamfers Tab
Chamfer (c1)
Schematic drawing
Preview
Bolts Tab
Horizontal arrangement
Group 1
Bolt properties
Schematic drawing
Connection and bolt arrangement values ​​are shown on the schematic drawing.
Preview
Welds Tab
Welds
Weld electrode
Schematic drawing
Preview
Gusset Plate Tab
Gusset plate
Gusset plate is determined by entering the value. The values ​​to be entered are shown in the schematic drawing.
Schematic drawing
Preview
Design Data Tab
