DPT 1302-61 2019
Analysis settings that vary depending on the DPT 1302-61 2019 are explained in detail.
:check_mark:
Download ideCAD for Seismic Code Design with DPT 1302-61 2019
DPT 1302-61 2019 Options Tab
Structural system type
The type of structural system for X and Y direction is selected in accordance with the design of the building.
Response modification coefficient
It is the response modification coefficient value. This row is automatically refreshed when the structural system type is chosen.
Overstrength factor
It is the strength excess coefficient value. This row is automatically refreshed when the structural system type is chosen.
Deflection amplification factor
It is the deflection amplification factor value. This row is automatically refreshed when the structural system type is chosen.
Redundancy factor
It is the redundancy factor value. This row is automatically refreshed when the structural system type is chosen.
Accidental eccentricity ratio
The eccentricity ratio to be used during the analysis is given as a percentage.
Use custom vertical seismic load factor
If checked, the custom vertical seismic load factor which entered in "factor to use (instead of 0.2 SDS)" line is used.
Structural system
If the building block consists of only concrete elements, Concrete; if it consists of only steel elements, Steel; Steel + Concrete option is selected if it consists of concrete and steel elements.
Building Risk Category
Building risk category value is selected from the list according to the purpose of use of the building.
Story drift check
Allowable story drift value is entered.
Response Spectrum Tab
Spectrum curve
The spectrum curve resulting from the settings is shown.
Function name
The name of the spectrum function.
Spectrum multiplier
Factor of spectrum function.
0.2 sec spectral acceleration (Ss)
0.2 sec spectral acceleration of spectrum function.
1 sec spectral acceleration (S1)
1 sec spectral acceleration of spectrum function.
Region
Select the region for the response spectrum from the list.
Damping ratio
Select the damping ratio for the response spectrum from the list.
Zone
Select the zone for the response spectrum from the list.
Site class
Site class is selected.
Short-period site coefficient (Fa)
Short-period site coefficient of spectrum function.
Long-period site coefficient (Fv)
Long-period site coefficient of spectrum function.
T0/Ts
Spectrum Characteristic Periods.
:check_mark:
Download ideCAD for DPT 1302-61 2019
NSCP 2015
