Creating a Level Dimension
The level dimension command is used to specify different elevations on the plan. Level dimensions are smart dimensions. It is updated automatically when the elevation or height of the object such as the wall, column, zone which it is located is changed.
If the elevation value is wanted to be entered, the relevant elevation object is explode into pieces and the value can be changed with the Edit Text command.
Location of the Level Dimension Command
In the Architectural Program
You can access it under the ribbon menu Drawings tab, Dimensions heading.
In the Structural Program
Dimension Toolbar
Icons
Outer dimension
Outer dimension command runs.
Inner dimension
Inner dimension command runs.
Free dimension
Free dimension command runs.
Intersection dimension
Intersection dimension command runs.
Label
Runs the label command. The dimension label is drawn.
Level dimension
Draws level dimension in the plan window.
Section elevation
It is used for section elevation in section and view windows. Only active in 2D drawing windows.
Angle dimension
Dimensions the angle between two objects.
Radius dimension
Dimensions entities drawn with a circle or arc and arc or circle axis in diameter or radius.
Section dimension group
Creates a section dimension group. It is active in section and view windows.
Section dimension
Creates a section dimension. It is active in section and view windows.
Include beams
Include beams in dimension.
Include slabs
Include slabs in section dimension.
Include details
Include door/window elements in section dimension.
Left side
Places the section dimension on the left.
Right side
Places the section dimension on the right.
Settings
When clicked, which dimension type is active (inner, outer, intersection etc.) opens the dimension settings dialog where the parameters related to that dimension are found.
To create a level dimension:
  • Click the Level Dimension icon in the ribbon menu .
  • Click with the left mouse button on the point where you want to specify its height in the plan window.
  • Level dimension will be drawn.
Determining the point to be level dimension in the plan window
Level dimension
Location of the Level Dimension Settings
Level Dimension Command Settings
You can access it under Level Dimension in the Drawings tab of the ribbon menu.
You can also access it by clicking the Settings icon in the dimension auxiliary toolbar that appears after the level dimension command is run.
Level Dimension Object Settings
Select the level dimension you want to enter its settings and click the Properties row from the menu that opens by clicking the right button of the mouse.
Level Dimension Settings - General Tab
Label Section
The size of the elevation icon is entered.
The angle of the elevation symbol is entered. The icon will rotate according to the entered value.
Colors Section
Sets the color of the elevation icon. When the color box is clicked, the appropriate color is selected from the window that opens.
One of the 5 display types given for elevation dimension is selected.
Text Section
By entering the values ​​entered in Text dx, and Text dy boxes, the position of the text is adjusted according to the label.
The height of the elevation lettering is adjusted.
When the button is clicked, the "Font Settings" dialog appears. Font of information text can be set here.
One of the 4 display types given for elevation text is selected.
Draw architecturalslab level on zones
Slab height is shown as elevation height.
Draw structural slab level on zones
When the elevation is placed on the floor, the elevation value is shown by adding the height of the floor and the floor elevation.
Global elevation
The elevation dimension value is given according to the building floor. If unchecked, the value is given according to the floor base.
Level Dimension Settings - Units Tab
Basic units
One of the selections is activated by clicking the left mouse button on the job.
Meter : If checked, the unit of information text will be meters.
Centimeter : If checked, the unit of the callout will be centimeter.
Millimeter : If checked, the unit of callout will be millimeter.
Feet and fractional inches : If checked, the unit of callout is feet and fractional inches. The unit format is, for example, 15 '-10 3/4 ".
Feet and decimal-digit inches : If checked, the unit of callout is feet and decimal-digit inches. Unit format is, for example, 15' -10.7".
Decimal place fit: If checked, the unit of callout will be decimal place fit. The unit format is for example 15.89 '.
Fractional inch: If checked, callout unit will be fractional inch. The unit format is, for example, 1901/2 ".
Inch with decimal places : If checked, the unit of callout is inches with decimal places. The unit format is for example 190.7".
Digit count
It determines how many digits will be shown after the comma. The desired number is selected from the list. For example, if 2 is selected, units will be shown as two digits after the comma. If 0 is selected, units will not be shown after the comma.
Fractions
It determines the precision of the dimension to be made in fractional inch format. In the list, there are options with a sensitivity of 1/2, ¼, 1/8, 1/16, 1/32, 1/34. If "no fraction" is selected, units will appear without fractions.
Rounding interval
It determines the rounding range of the measurement to be made in meters, centimeters or millimeters. If No rounding is selected, the dimensioning is done at exact value. As the range gets larger, the dimensioning is rounded up to the selected range.
Show zero unit
If it is not checked, it does not show the zero and point on the left in dimensioning. For example, it measures 0.20 as 20. If marked, the value 0.20 is scaled as 0.20.
Small fraction text
When fractional inch format is selected, determines the fractional part to display in upper / lower case. If it is checked, the fraction is slightly above the integer and small, if not, the fraction is shown the same size next to the integer.
Show zero foot
Determines whether 0 is displayed in the 0-foot gauge (less than 1 foot gauge). For example, if it is not checked, it will show a measure of 0 '- 15 "as -15". If marked, it shows as 0'-15 ".
Show zero inch on 0-1 inch range
For example, a dimension inch with a value of 8'-0 1/6 "is in the range 0-1. If the option is not ticked, the value 8'-0 1/6" will be displayed as 8'-. In other words, inch values ​​in the 0-1 range will not be displayed.
Show absolute zero inch
Determines whether to show zero inches in the dimension value where inches is absolute zero. For example, a dimension of exactly 10 'will be displayed as 10'-0 "if this option is selected. If not checked, it will be displayed as 10" -.
