Show Axis in Sections and Elevations
The representation of the axes in the sections and elevations and the way they are displayed are decided from the settings of the axis lines.
Location of Axis Lines Settings
You can access the settings from the Axis Lines tab of the Section/View settings dialog .
Placement
Where the axes in the section/elevation plane will be shown in the drawing are determined by marking the desired options from the top, middle and the bottom options. The distance of the axes from the drawing and the values ​​for the axes lengths are entered in the boxes in the schematic drawing.
Circle radius
It is the radius value that determines the size of the axis circles shown in the section/elevation drawing.
Text height
It is the value determining the text size of the axis names shown in the section/elevation drawing.
Automatic text height calculation
If the automatic text height is marked, the size of the axis names is determined automatically according to the size of the axis circle, the given text height is not taken into account.
Line color
Determines the color of the axis lines. You can choose another color from the color dialog that opens when clicked.
Text color
It determines the color of the axis text. You can choose another color from the color dialog that opens when clicked.
Line type
Determines the line type of axis lines. Clicking on the drop-down list can choose another type.
Font
Determines the font of the axes text. Clicking on the drop-down list can choose another type.
Extend to lines
All axises are roof or wall etc. It is extended according to the form of the objects.
Extend to boundary
All axises are roof or wall etc. It is extended to an alignment with respect to the top point of objects.
Show all axes
Shows all axises that are within the section/elevation plane.
Show concrete section axises
Columns, beams and shearwall etc. within the section/elevation plane. shows the axes that pass over the elements and determine the concrete construction.
Examples of Different Axis Settings
When axis lines are not active
When axis top placement option is active
When axis top placement option and extend to boundary are active
When show concrete section axises is active
