Defining a Box/Tube Cap Plate
With the Box/Tube Cap Plate command, cap plate for the box/tube profiles is created.
Location of the Box/Tube Cap Plate Command
  • Click Box/Tube Cap Plate icon from the Connection menu.
  • Click the elements you want to connect sequentially from the 3D perspective view.
  • The connection will occur.
  • Click the column from the 3D perspective view.
Location of the Box/Tube Cap Plate Connection Settings Dialog
General Tab
Cap plate
The cap plate is determined by entering the value. The values ​​to be entered are shown in the schematic drawing.
Schematic drawing
Preview
Welds Tab
Welds
Weld electrode
Schematic drawing
Preview
Design Data Tab
