Reset Dimension Texts
The Reset Dimension Texts command cancels and resets any changes made to the dimension at once.
Location of the Reset Dimension Texts Command
Select the dimension you want to return to its original state, click the right mouse button and click the Reset Dimension Texts line from the menu that opens.
In the Architectural Program
You can access it under the Ribbon menu Modify tab, Entity Edit title.
In the Structural Program
  • Select the dimension you want to reset.
  • Click the Reset Dimension Texts icon in the ribbon menu or click the right button of the mouse and click the Reset Dimension Texts line from the drop-down list .
  • “Selected dimension texts displacements will be reset. Proceed?" Answer the warning by clicking the "Yes" button.
  • Your dimensioning will come first.
Before reset dimension texts
Selection of dimension
“Selected dimension texts displacements will be reset. Proceed?" Response to warning
After reset dimension texts
