Slab thickness for punching reinforcement min. Should be 25cm
The Complete Message:
In order to use punching equipment, the slab thickness must be min. Should be 25cm
In TBDY article 7.11.10, if the τ pd ≤ f ctd condition is not fulfilled and the plate thickness is not less than 250 mm, the punching strength of the plate can be increased by using reinforcement.
Solution
Give the floor thickness of the floor given its name and floor at least 25 cm.
