Sloping Flat Truss
With the Sloping Flat command, the sloping flat truss type which is one of the prepared truss types, dis drawn quickly. Truss heights are adjusted from the truss settings.
Sloping Flat Truss Schematic Drawing:
Location of the Sloping Flat Command
  • Click on the sloping flat command.
  • In the Heights tab , enter the heights h2, h3 and h4 for sloping flat.
Entering 80 cm for h2, h3 and h4 in the height tab of the truss settings
