Saving a Screenshot
With the "Export/Plan Screenshot" option, the plan screen is saved as an image.
  • Click the ideCAD icon/Export/Plan Screenshot icon in the ribbon menu   .
  • The Save Image dialog will open.  Click the OK button after the desired settings are made  .
  • The Save Image dialog opens. In the file types section below, determine which format you will save.
  • Type a name in the file name line. When you click the OK button, your plan screen will be saved as an image.
Inclined Column
