Creating a Label
With the label command, notes are made at the designated points in the projects, and the label type and dimensions are adjusted.
Location of Label Command
In the Architectural Program
You can access it under the Ribbon menu Drawings tab, Dimension heading.
In the Structural Program
Dimension Toolbar
Icons
Outer dimension
Outer dimension command runs.
Inner dimension
Inner dimension command runs.
Free dimension
Free dimension command runs.
Intersection dimension
Intersection dimension command runs.
Label
Runs the label command. The dimension label is drawn.
Level dimension
Draws level dimension in the plan window.
Section elevation
It is used for section elevation in section and view windows. Only active in 2D drawing windows.
Angle dimension
Dimensions the angle between two objects.
Radius dimension
Dimensions entities drawn with a circle or arc and arc or circle axis in diameter or radius.
Section dimension group
Creates a section dimension group. It is active in section and view windows.
Section dimension
Creates a section dimension. It is active in section and view windows.
Include beams
Include beams in dimension.
Include slabs
Include slabs in section dimension.
Include details
Include door/window elements in section dimension.
Left side
Places the section dimension on the left.
Right side
Places the section dimension on the right.
Settings
When clicked, which dimension type is active (inner, outer, intersection etc.) opens the dimension settings dialog where the parameters related to that dimension are found.
To create a label:
  • Click the Label icon in the ribbon menu .
  • Click three points with the left mouse button in the drawing area. The two-part label will appear in the drawing area, and a dialog for the label text will appear.
  • Enter the text in the dialog that opens and click the OK button. The label will be drawn.
Determining the first point of the label
Determining the second point of the label
Determining the third point of the label
Entering the tag text
Creation of the label
It is not possible to change the label text in Label Settings . If you want to change the tag text, the Edit Label Text command should be used.
Location of the Label Settings Dialog
Label Command Settings
After the label command is run, you can access it by clicking the Settings icon in the dimension toolbar that appears on the screen.
Label Object Settings
Select the label that you want to enter its settings and click the Properties row from the menu that opens by clicking the right button of the mouse.
Label Settings
Drawing color
 Sets the color of the label lines. When the color box is clicked, the appropriate color is selected from the window that opens.
Text color
Sets the color of label posts. When the color box is clicked, the appropriate color is selected from the window that opens.
Text height
Label height is entered.
Text angle
Label text angle is entered.
When the button is clicked, the "Font Settings" dialog appears. Font of information text can be set here.
Label tip
One of the 4 display types given for the label line end is selected.
Label
Label line end dimensions are determined by entering values ​​in the X and Y boxes.
