Fix the Failures
The project, which was prepared with ideCAD Architectural, was opened with ideCAD Structural. By making Analysis+Design, you can identify the failures with visualization possibilities and make the necessary intervention.
Fix the Failures.cde
  • Click on the Analysis+Design (F9) command.
  • The Analysis Settings dialog will open.
  • Click the OK button to start the analysis.
  • Wait for the analysis to complete in the Analysis Status window.
  • After the analysis is complete, click the OK button to close the window.
  • A red cross will be seen on the Output heading Concrete All Failures.
  • Open the Concrete All Failures list.
  • Click on the Concrete Column-Beam Joint Area.
  • Elements with this failure appear in red in the Visualization Window.
  • Concrete Column-Beam Joint Area failure should be eliminated.
  • Close the visualization dialog.
  • Open the Column Settings dialog by double-clicking on the S10 column.
  • In the General tab, write 30 cm for width value and 40 cm for height value.
  • Open the STORTY 1 CEILING page.
  • Click the Analysis+Design (F9) command.
  • Do you want to perform analysis? question will be asked.
  • Click the Yes button.
  • Wait for the analysis to complete from the Analysis Status window.
  • A green tick will appear on Concrete All Failures in the Output heading.
  • This sign means that there is no failures in the project.
  • Click on the Concrete Column-Beam Joint Area failure.
  • Concrete elements will be displayed in green in the Visualization Window.
  • There is no Concrete Column-Beam Joint Area failure in the project.
