Defining an Arc-Shaped Polygon Column
Two different methods can be used to create an arc-shaped polygon column. The choice is made according to the desired polygon view.
Arc Through 3 Points Polygon Column
Create the plan of the polygon column you want to create from the arc through 3 points and multiple lines commands.
  • Click on the arc through 3 points icon.
  • Determine the start and end points of your broadcast by clicking with the left mouse button.
  • Your bow will change with the movement of your mouse. Complete the arc drawing by clicking the 3rd point with the left mouse button.
  • Click the offset icon from the ribbon menu for the other side of your polygon column.
  • Enter the toolbara offset value that opens and click with the left button of your mouse on the side you want to create a copy of.
  • Click the multiple line icon from the ribbon menu.
  • Cover the ends of your polygon column.
  • Select your drawing and click the right mouse button. Click the Transform/To Polygon Column row from the drop-down list.
  • Your polygon column will be formed.
Polygonal Column from Beam
You can use this method to get a fractured image in your polygon column.
  • Your bow will change with the movement of your mouse. Click on point 3 of your mouse to complete the arc drawing.
  • Select the spring and right click the mouse and click the Transform/To Beam line from the list.
  • The purpose of converting beams is to create the shape of the polygon column by traversing the beam nodes with a line. In the dialog that opens, set the number of beams and set the fracture amount.
  • Your beams will be formed.
  • Click the multiple lines icon.
  • Go around the perimeter of the beam, catching the joints.
  • Delete the beams and bow so only the lines remain.
  • Select the lines and right click the mouse and click the Transform/To Polygon Column line from the list.
