Defining a Box/Tube Splice Connection
With the Box/Tube Splice Connection command, tube and box section columns or beams are combined with a splice connection.
Location of the Box/Tube Splice Connection Command
  • From the Connection menu, click the Box/Tube Splice Connection icon.
  • Click element 1 with box and / or tube profile before 3D perspective view, then click element 2 with box and / or tube profile
Location of the Box/Tube Splice Connection Settings Dialog
Plates Tab
End plates
End plates are determined by entering values. The values ​​to be entered are shown in the schematic drawing.
Stiffener plates
Stiffener plates are determined by entering the value. The values ​​to be entered are shown in the schematic drawing.
Schematic drawing
Preview
Welds Tab
Welds
Weld electrode
Schematic drawing
Preview
Connection Bolts Tab
Horizontal arrangement
Group 1
Bolt properties
Schematic drawing
Connection and bolt arrangement values ​​are shown on the schematic drawing.
Preview
Chamfers Tab
Chamfer (c1)
Schematic drawing
Preview
Design Data Tab
