With ideCAD Structural, concrete structures are analyzed and designed with the DGT approach. Concrete design is made by applying TBDY 2018 and TS 500 conditions. Concrete design parameters and reinforcement and concrete parameters (spacers, minimum pursantage, minimum stirrup spacing, shear cross reinforcement type, etc.) to be used in the design of reinforced concrete elements (column, beam, slab, shear, foundation, retaining wall, etc.) are determined. Concrete design results, reinforcement layout, reinforcement diameter and reinforcement spacing are examined from the concrete element design dialogs and interventions are made when necessary.
Rebar Selection -
Mesh Wire Settings -
General Concrete Reinforcement Parameters -
Column Parameters -
Beam Parameters -
Shearwall Parameters -
Slab Parameters -
Ribbed-Waffle Slab Parameters -
Single Footing Parameters -
Strip Foundation Parameters -
Raft Foundation Parameters -
Stair Parameters -
Dome Vault Parameters -
Retaining Wall Parameters -
Well Foundation Parameters -
Pile Parameters -
Foundation Tie Parameters
