The individual foundation base pressure value means that it exceeds the Ground Bearing Force (q t ) value entered in the Analysis Settings dialog .
This message is created at the beginning of the report by giving the name of the element and its solid.
For example, T08 Basement Floor
Solution:
Increase the floor area.
After the solution processes, the analysis should be repeated.
