Adding/Deleting Partitions
When the scaffolding is first created, partitions will be according to your unit size. With the Partition count setting, a partition is added later or an existing partition is deleted.
Location of Partition Count Setting
Select the scaffolding you want to add/delete and click the right mouse button. Click Properties from the right-click menu that opens.
  • Select the scaffolding you will add and enter its settings.
  • Increase the number of partitions in the scaffolding tab. For example, change the count of partitions from two to four.
  • Partitions will be added to your scaffolding.
  • You can delete existing partitions by reducing the count of partitions.
Before increasing the count of partitions
After increasing the count of partitions
