For A32 ∑Mdev / Mo> = 0.75.
The Complete Message:
∑Mdev / Mo> = 0.75 in limited ductility level A32 systems in (X / Y) direction.
A32 type of system that transmits torque of the earthquake impact ductility level limited by reinforced concrete frames ductility limited is defined as buildings that are covered by the spaces with reinforced concrete walls.
4.3.4.7 agent dolayısıul to s üneklik level limited spaces reinforced concrete walls or ductility limited central steel braced frames torque transmitting ductility limited in buildings is used with concrete or steel frame Eq. (4.3) 't given condition must be provided.
∑ M DEV ≥ 0.75 M o                                            (4.3)
Possible solutions:
  • A curtain / curtain group can be added to the carrier system until the Equation 4.3 condition is met.
  • The structure can be designed by choosing high ductility level instead of limited.
Icons:
