Creating a Concrete Slab
Concrete slab is created with the Concrete Slab command. Concrete slab is the load-transfer element drawn between steel beams and on secondary beams.
Location of Concrete Slab Command
You can access it under the ribbon menu, Steel tab, Steel title
  • Click the Concrete Slab icon from the ribbon menu .
  • The slab for steel toolbar will open.
  • Click on the settings icon on the far right. It contains the opened concrete thickness, material and load information parameters.
  • Choose the first of the steel beams.
  • You have selected the steel beams to form a closed polygon and finish by right clicking on the last beam.
  • Your concrete slab will be formed.
Area to create concrete slab
Choosing the first steel beam
Choosing the second, third and fourth steel beam to form a closed polygon
The formation of the concrete slab
Metal Slab Settings
