Defining a Stay Connection (Secondary Beam)
With the Stay Connection (Secondary Beam) command, beam-beam or beam-secondary beam connection is defined.
Opposing steel beams or steel beams connect the secondary steel beams with angle plates.
Location of the Defining a Stay Connection (Secondary Beam) Command
  • From the Connection menu, click the Stay Connection (Secondary Beam) icon.
  • First choose the main beam. Then choose the other beam or subsidiary beam parallel to it.
  • The program will ask the distance to start. The value to be given is the distance to the left end.
  • If the distance is given and OK is clicked, the connection will occur with default settings.
Location of the Stay Connection (Secondary Beam) Settings Dialog
Type Tab
Connection type
Connection type is selected for support and secondary plate.
Diagonal type
It is chosen whether the diagonal will be on the left or right or both sides.
Connection direction
It is selected whether the connection will be from top or bottom.
Schematic drawing
Connection and placement values ​​are shown on the schematic drawing.
Preview
Plates Tab
Support plate
The support plate is determined by entering the value. The values ​​to be entered are shown in the schematic drawing.
Secondary plate
The secondary plate is determined by entering the value. The values ​​to be entered are shown in the schematic drawing.
Position
The location of the secondary beam is determined by entering the value. The values ​​to be entered are shown in the schematic drawing.
Schematic drawing
Preview
Angle Tab
Define plate geometry
If the option is selected, it is determined by entering the angle values. The values ​​to be entered are shown in the schematic drawing.
Use section
By selecting the option, one of the ready-made L profiles is selected from the list as an angle. By clicking on the load section button, you can reach the ready section library and reach the list of American and European finished rolling sections and select from the list.
Length
The angle length to be used is determined by entering the value.
Schematic drawing
Preview
Chamfers Tab
Chamfer (c1)
Schematic drawing
Preview
Welds Tab
Welds
Weld electrode
Schematic drawing
Preview
There is a preview of the conection. The selection made and the entered values ​​can be followed simultaneously in the preview.
Connection Bolts Tab
Horizontal arrangement
Group 1
Bolt properties
Schematic drawing
Connection and bolt arrangement values ​​are shown on the schematic drawing.
Preview
Design Data Tab
