Shearwall reinforcement design results and inadequacy of shears are displayed in the Shearwall Reinforcement dialog. In the shearwall reinforcement dialog, shearwall transverse and longitudinal reinforcements, head zone reinforcements, internal forces calculated as a result of the analysis, increased internal forces related to TBDY, and capacity ratio results are given. The body and head area reinforcements of the shearwalls can be changed and fixed in the Shearwall Reinforcement dialog.
Location of Shearwall Reinforcements Dialog
After analysis, you can access it by clicking on the Shearwall Reinforcements command under the Concrete Design title of the ribbon menu Analysis and Design tab .
General Specifications of Shearwall Reinforcements Dialogue
Summary Information The summary information about the line where the cursor is located is given in the form of story name, in the name section of the dialog.
For example Base Story, P1 |
Using the Shift key In this tab, you can select more than one row with the Shift key, enter a value by double-clicking any cell whose value is open to change, and you can make that value apply to all selected rows. |
Using the Ctrl key Ctrl key, on the other hand, selects the lines in between one by one. |
Reinforcement calculator Calculates the amount of rebar, in area, for the selected diameter and span. |
Show only reinforcement shearwalls It only lists the rebar shearwalls. |
All Stories It lists the slabs on the screen throughout the entire story. |
Select Selects the object on the line with the cursor. When the concrete dialog is closed, you can take action for the selected element. |
Filter It is used to define certain conditions and filter only the elements that satisfy that condition. |
Recalculate The element rebuilds its concrete. The regulation calculations related to concrete and rebars are also made again. It may be more appropriate to repeat the structure analysis instead of concrete in important changes. |
Ok It saves the changes made and closes the dialog. |
Insufficiency Code Description and Recommended Solution
Insufficiency Code |
Description |
K |
Shear safety is not satisfied.
F |
Friction-based shear capacity is not satisfied.
E |
The maximum axial load capacity is exceeded.
M |
The maximum reinforcement ratio is exceeded.
ab |
The hook development length is not satisfied as per the Seismic Design Code.
As(-) |
The provided longitudinal reinforcement is insufficient.
As(-)B |
Transverse reinforcement in the wall boundary region is insufficient.
Z |
Punching shear capacity is exceeded (typically in slab-wall connections).
T |
The transfer of seismic forces from the slab to the wall is not satisfied according to the Seismic Design Code.
W |
Strong wall condition is not satisfied according to the Seismic Design Code.
R |
The capacity ratio under axial load and biaxial bending exceeds 1.0.
Shearwalls Tab
DS If marked, the rebar is fixed. When the shearwall is changed, DS is automatically marked and when concrete is made, the shearwall also remains constant. If DS is not marked, when concrete is made, shearwall rebar is determined again according to rebar selection conditions. . |
ID
It is the name of the shearwall in the plan. (P1, P101, P10 etc.) In case of negativity, a term related to negativity is added next to the name. Like P101 (E) .. |
Story
Indicates the story where the shearwall is located. |
B
It is the width of the shearwall. |
lw
It is the length of the shearwall. |
HeadL
It is the value of the rebar in the left region in terms of quantity and diameter. |
Middle
It is the value of the rebar in the middle region in terms of quantity and diameter. The shearwall mesh reinforced shearwall is written as the mesh rebar type in the cell. |
HeadR
It is the value of the right area rebar in terms of quantity and diameter. |
Stirrup
It is the diameter and spacing of the stirrup of the shearwall body region. |
Head Stirrup
It is the diameter and spacing of the stirrup of the shearwall heading area. |
Vd
It is the shear force calculated under the combined effect of vertical loads and earthquake loads. |
Ve
It is the design shear force calculated according to TBDY 7.6.6 and based on the shear transverse reinforcement calculation. |
Vr
Shearwall shear design strength. |
VeMax
It is the maximum shear force that the shearwall can take, calculated according to TBDY Equation 7.18. |
Cap. Ratio
It is the largest of the capacity ratios calculated under the effect of axial force and biaxial bending, under the effect of all combinations in the existing reinforcement layout. |
Fiber Layout Tab
Preview and legend
The fiber layout preview and what the colors mean are shown. |
Material model for DGT Section cells and rebars are displayed according to the concrete and rebar material model criteria defined in TS500. |
Material model for SDGT The section cells and rebars are displayed according to the ŞGDT criteria for the concrete and rebar material model defined in TBDY. |
Forces - Reinforcement Areas Tab
Table of forces
Load: The name of the respective load or load combinations.
Reinforcements (calculated - required - existing)
Respectively; The area of rebar found from the most unfavorable loading combination, the amount of rebar to be placed according to the regulations and minimum rebar conditions and the total values of the final selected rebar in the left, middle and right regions for the shearwall are given. Design: It is the name of the combination used in reinforcement calculation.
Design results After the analysis, the regulation conditions have been applied, therefore it shows the end forces that have undergone changes and going to the design. In addition, the values used are shown in bold. End forces are values calculated on the element local axes. |
Raw results After analysis, it shows the raw end forces that are not applied to the regulation conditions. End forces are effects on the element local axes. |
Global results After the analysis, these are the values in global coordinates of the extreme forces that are not applied regulation conditions. |
Show individual results For 4 modal analysis cases, 4 different results are obtained from each earthquake loaded combination. If you want the program to display the values obtained for each modal state one by one, you should check this option. |
Show maximums The biggest values of 4 different results obtained from each load combination for 4 different modal cases are shown in the table. |
Geometric properties hw: The total height of the shearwall throughout the structure.
Material properties
Structural material: The structural material of the shearwall.
Shear force
Detailed information on shear force control according to TDY is printed. In walls with high ductility level with Hw / Lw> 2;
Capacity Design Tab
Capacity chart
Combination: The corresponding combination is shown.
Existing area of steel The available rebar area values for end i, span, and end j are shown. |
Capacity Diagrams Tab
Bending about 2 axis
Bending about 3 axis
SDGT - (new structure) The section cells and rebars are displayed according to the ŞGDT (new structure) criteria for the concrete and rebar material model defined in TBDY. |
SDGT - (existing str. - limited information) The section cells and rebars are displayed according to the ŞGDT (existing structure - limited information) criteria for the concrete and rebar material model defined in TBDY. |
SDGT - (existing str. - comprehensive info) The section cells and rebars are displayed according to the ŞGDT (existing structure - comprehensive information) criteria for the concrete and rebar material model defined in TBDY. |
Design case The combination for the capacity diagrams to be examined can be selected from the list. |
Moment - Curvature Tab
Schematic drawing
Moment - curvature diagram
Use CP curvature = ultimate curvature When this option is selected, the ultimate strain of the concrete and reinforcement material is used to calculate the plastic rotation limit values for performance levels. |
Caltrans idealized model If marked, the moment-curvature plot is idealized. It is a moment curvature relationship obtained by drawing a horizontal line that intersects with an inclined line passing over the moment of yield and will equalize the areas between the moment curvature graph. |
Stop when a fiber reaches ultimate stress If checked, the graphic ends when the graphic fiber reaches its highest stress. |
SGDT
The section cells and rebars are displayed according to the SGDT criteria for the concrete and rebar material model defined in TBDY. |
Point count It is used to determine how many points the moment curvature graph consists of. |
Angle It shows the neutral axis angle from which the moment curvature relationship is obtained. It is indicated with a red arrow in the image above. |
Axial force It shows under which axial force the moment curvature relationship is drawn. |
Compression limit The determined material model is the largest axial pressure force that the section can take in the moment-normal force interaction. |
Tension limit The determined material model is the largest axial tensile force that the section can take in the moment-normal force interaction. |
View stress/strain contours It shows the stress and strain state in section in color format at each step of the moment curvature relationship. |
Generate report Creates a detailed report of moment-curvature. |
Equation 7.3 Control Tab
In this tab, detailed information is given about strong column control in the shearwall long direction according to TDY.
Control table
Major (+): It is the moment of carrying capacity of the bulkheads in the major direction calculated according to the earthquake + direction.
Mr(c): Sum of nominal flexural strengths of shearwalls (Mra, Mrü) framing into the joint, evaluated faces of joint.
(Mra + Mrü) Major: For strong column control, it is the sum of the moments of bearing strength in the long direction of the shearwall (in the 3 axis), above and below the shearwall.
(Mra + Mrü) Major> 1.2 (Mri + Mrj) Major control is checked. If not, shearwall sizes are increased. |
In case of Nd≤ 0.10 Ac fck in both columns joining the node point, or at the nodal points of the top floor of single-storey buildings and multi-storey buildings, or if the shearwall where the beams are stuck working like a column in a weak direction, the above condition is not compulsory. The bottom line is; Displays whether Nd is greater than 0.1AcFck. |
Nd: It is the axial force value that makes these moments the smallest in accordance with the direction of the earthquake in the calculation of column bearing force moments.
Reinforcement Bars Tab
3D image
Show columns If the option is selected, column rebars are shown on the screen. |
Show beams If the option is selected, beam rebars are shown on the screen. |
Show shearwalls If the option is selected, shearwall rebar is shown on the screen. |
Show longitudinal bars Longitudinal bars of the elements with option marked are shown on the screen. |
Show transverse bars The transverse rebars of the elements with options are displayed on the screen. |
Show individual colors If the option is selected, bars with different diameters are shown in different colors. Which color represents which diameter is on the right of the screen. If the option is off, all of the rebars are shown in red. |
