Minimum diameter of tie bar is controlled automatically according to Codes.
Minimum and maximum clear spacing of ties are controlled according to Codes.
Minimum spacing of spirals are controlled according to Codes.
Minimum diameter of spiral is controlled automatically according to Codes.
The volumetric spiral reinforcement ratio ρs is controlled according to Codes.
İnternational Design Codes
ACI 318-19 : Transverse Reinforcement
TSC 2018 : Column Transverse Reinforcement Detailing and Limits Transverse Reinforcement Detailing for Beams.
dagg = Nominal maximum size of coarse aggregate, in.
Ach = cross-sectional area of a member measured to the outside edges of transverse reinforcement, in.2
f'c = specified comprehensive strength of concrete, psi
Ag = gross area of concrete section, in.2 For a hollow section, Ag is the area of the concrete only and does not include the area of the void(s)
ρs = ratio of volume of spiral reinforcement to total of core confined by the sprial, measured out-to-out of spirals
