Vertical Frame Plane
Vertical frame planes are created in the desired amount in the vertical alignment of the selected axis by selecting the axis. One of the orthographic or perspective projection type is selected.
Location of Display Vertical Frame Command
You can access it from the View tab , Workplane heading in the ribbon menu .
  • Click the Display Vertical Frame command.
  • Click an axis on any floor
Sample application for vertical frame plane in 5 axis:
Vertical frame view in deformation mode in analysis model view:
Clip Plane
