Part 52. Review Steel Design
In this tutorial, review steel design.
1. Use the Steel PMM Failures command from Output heading.
2. Select the PMM ratios from Design Output list in the visualization dialog.
3. Select the Deflection failure from Design Output list.
4. Use the Column command from Design heading in the Steel tab.
5. Check the steel column sections, PMM ratios and combinations in the Steel Columns dialog.
6. Check the design details of the steel column by clicking the Details button.
7. Use the Beam command from Design heading in the Steel tab.
8. Check the steel beam sections, PMM ratios, combinations and deflection control in the Steel Beams dialog.
9. Check the design details of the steel beam by clicking the Details button.
