Noncomposite Castellated Beam Design Results
Noncomposite castellated beam design results and noncomposite castellated failure conditions are displayed in the Noncomposite Castellated Beams dialog. In the Noncomposite Castellated Beams dialog, shear, body buckling, vierendeel controls in gross and net area, as well as internal force results and net moment of inertia calculation are also given.
Location of Noncomposite Castellated Beams Dialogue
After the analysis is done, you can access it by clicking the Noncomposite Castellated Beam Design Results command under the Steel Design heading in the ribbon menu Analysis and Design tab .
General Specifications of Noncomposite Castellated Beams Dialogue
Summary Information
The summary information about the line where the cursor is located is given in the name of the dialog in story, pose format.
For example, STORY 1, SB001
Using the Shift key
In this tab, you can select more than one row with the Shift key, enter a value by double-clicking any cell whose value is open to change, and make that value apply to all selected rows.
Using the Ctrl key
Ctrl key selects the lines in between one by one.
Previous
The cursor moves to the previous line.
Next
The cursor goes to the next line.
OK
It saves the changes made and closes the dialog.
Cancel
Closes the dialog without saving the changes made.
Design Checks Tab
ID
Castellated is the name of the beam in the plan.
Section
It is the section used in honeycomb beam.
Material
Castellated is the material class of the beam.
PMM ratio
It is the ratio of requirement to cross section capacity (PMM Ratio = Need/Capacity).
Shear (Gross)
It is the ratio of shear force to capacity in gross section.
Shear (Net)
It is the ratio of the shear force to the capacity in the net section.
Horizontal shear
It is the ratio of shear force to capacity in horizontal section.
Web post buckling
It is the ratio of the twisting moment in the body to the capacity.
Vierendeel bending
Vierendeel is the ratio of need to capacity according to castellated beam calculation.
Deflection
Deflection value of castellated beam.
Check
It is an information box whose sign changes according to the presence or absence of negativity in the section.
Design Details Tab
Deflection
Combo: It is the combination that creates the most unfavorable section forces.
Deflection: It is the deflection formed in the honeycomb beam.
Span: Castellated is the length of the beam.
Limit value: The limit deflection value of the beam according to the regulation.
Ratio: It is the ratio of deflection made by the beam to the limit value.
Axial force and biaxial bending
Location: It is the position of the section forces taken into account in the design on the beam.
Pu: It is the axial load value.
Mu3: It is the moment value acting on the element in 3 direction.
Mu2: It is the moment value acting on the element in the 3 direction.
Pc: The axial load capacity of the honeycomb beam.
Mc3: It is the moment capacity of the element in 3 directions.
Mc2: It is the moment capacity of the element in 3 directions.
Interaction equation: It is the interaction equation of design.
Ratio: It is the moment-to-capacity ratio.
Shear (Gross)
Vu: It is the shear force acting on the element.
Vc: It is the shear force capacity of the element.
Ratio : It is the ratio of the shear force of the element to the capacity.
Shear (Net)
Ratio: It is the ratio of the shear force of the element to the capacity.
Horizontal shear
Web post buckling
Mu: It is the moment value acting on the element.
Mc: Moment capacity of the element.
Ratio: It is the ratio of the moment acting on the element to the capacity.
Vierendeel bending
Interaction equation: It is the interaction equation used in ratio calculation.
Ratio: It is the moment-capacity ratio found by the interaction equation.
Force and Moments Tab
i
The web post and opening in the honeycomb beam are listed.
x
It shows the location where the relevant forces and moments are located.
Vu
Mu3
Mu2
It is the moment value acting on the element in 2 direction.
Pv
It is the axial force value.
Mv3
Mv2
Vh
Shear force acting on the element.
Mh
Section Details Tab
Section properties
Ix, net: Shows the net moment of inertia in the x direction.
T section properties
A: Shows the section area.
J: Shows the Polar Moment of Inertia.
Ix: Shows the moment of inertia in the x direction.
Iy: Shows the moment of inertia in the y direction.
ix: Shows the radius of inertia in the x direction.
iy: Shows the radius of inertia in the y direction.
Wex, üst: Indicates the moment of elastic strength in the x direction in the upper cap region.
Wey, üst: Indicates the moment of elastic strength in the y-direction in the upper cap region.
Wex, alt: Shows the moment of elastic strength in the x direction in the subheading region.
Wey, alt: Indicates the moment of elastic strength in the y-direction in the subheading region.
Wpx: Shows the plastic strength moment in the x direction.
Wpy: Shows the plastic strength moment in the y direction.
